- Binding redcon cm921 9 ch rx to hmx 280(Help)
- C0ckpitvue 777
10 Sep 2016 20:01 - 10 Sep 2016 20:05 #53766
by C0ckpitvue 777
Binding redcon cm921 9 ch rx to hmx 280(Help) was created by C0ckpitvue 777
Trying to arm my hisky hmx 280 bnf version using my devo 10 after binding the redcon cm921 to the dsm2 deviated protocol.The receiver is binded to the tx because I get the solid orange light on the rx once the tx communicates.I attempted 2 arm sequences I saw,the first was the aileron stick to the lower left corner for 3 secs to no avail and the other was a combination of both sticks the left stick to the lower right corner and the right stick to the lower left.Both ways didn't engage or arm the motors.If anyone can help me get this bird to spread its wings it will be greatly appreciated.Also don't know if the rear green lights are supposed to continually blink on the quad once the quad is binded but that's what I'm getting.
Last edit: 10 Sep 2016 20:05 by C0ckpitvue 777.
- Thomas.Heiss
10 Sep 2016 23:20 #53774
by Thomas.Heiss
Replied by Thomas.Heiss on topic Binding redcon cm921 9 ch rx to hmx 280(Help)
Maybe Throttle trim below?
Have you tried that for actual ESC arming?
Any Hiskay manual?
Maybe the motor startup sequences are Mode dependent (especially for sticks in vs out)??
Thomas
Any Hiskay manual?
Thomas
- C0ckpitvue 777
11 Sep 2016 00:00 #53776
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Binding redcon cm921 9 ch rx to hmx 280(Help)
Hey Thomas appreciate the fb,I tried every sequence and trim to no avail.Still trying to figure it out.I'm getting so pissed off I'm starting to smell like urine.
- C0ckpitvue 777
11 Sep 2016 05:58 #53780
by C0ckpitvue 777
Does anybody have a dsm2 model ini,they would like to share for a devo 10 using a with redcon cm921 rx used on a hmx 280?It will be greatly appreciated.
- C0ckpitvue 777
11 Sep 2016 19:30 - 11 Sep 2016 19:33 #53796
by C0ckpitvue 777
Is anyone flying a multi rotor with this redcon dsm/dsm2 receiver with a devo 10?
www.banggood.com/REDCON-2_4G-9CH-CM921-D...ble-p-1015761.html.I
brought this version of the hmx280
www.banggood.com/HiSKY-HMX280-HMX-280-4C...tter-p-983328.html.I
successfully bound the receiver to the dsmx deviated protocol using the devo 10 but when I plug it in into the quad and try to arm it,nothing happens.This is the model ini.I'm currently using..Any help will be greatly appreciated.
name=Model25
mixermode=Advanced
[radio]
protocol=DSMX
num_channels=7
fixed_id=123456
tx_power=10mW
[protocol_opts]
Telemetry=Off
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=-1,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
value=-2,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
value=-64,0,0
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
name=Model25
mixermode=Advanced
[radio]
protocol=DSMX
num_channels=7
fixed_id=123456
tx_power=10mW
[protocol_opts]
Telemetry=Off
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
value=-1,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
value=-2,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
value=-64,0,0
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Model=75,20
Battery=102,1
TxPower=102,7
Last edit: 11 Sep 2016 19:33 by C0ckpitvue 777.
- aMax
11 Sep 2016 21:32 #53799
by aMax
Replied by aMax on topic Binding redcon cm921 9 ch rx to hmx 280(Help)
Any setup done on the flight controller?
- C0ckpitvue 777
11 Sep 2016 22:19 #53800
by C0ckpitvue 777
Thanks Amax appreciate the link,I already saw this.This is with the stock set up.I'm looking for the dsmx sat receiver set up.
- jesmail
12 Sep 2016 15:50 #53817
by jesmail
Replied by jesmail on topic Binding redcon cm921 9 ch rx to hmx 280(Help)
Check the channel assignments in your software. Make sure the direction of travel is correct.
Most controllers will not ARM if the direction of the controls is not correct.
- C0ckpitvue 777
13 Sep 2016 00:48 - 13 Sep 2016 00:49 #53829
by C0ckpitvue 777
Thanks for all your help I greatly appreciate it.I figured it out,I had to set up the devo to the ccrd flight controller using libre pilot,at first it wasn't recognizing the tx because I was putting in the wrong port setting for the receiver port.
Last edit: 13 Sep 2016 00:49 by C0ckpitvue 777.
Time to create page: 0.285 seconds
