Corrupt hardware.ini
30 Oct 2016 13:47 #55520 by Birrel
Corrupt hardware.ini was created by Birrel
I have a new Devo 7e with a 3 in 1 module installed. Everything is working fin, but when i shut down the tx, the next day i can't bind anymore. I entered usb mode, and find out that my hardware.ini is corrupt. I am using 5.0.0.
30 Oct 2016 17:49 #55526 by hexfet
Replied by hexfet on topic Corrupt hardware.ini
Does this consistently happen every time you power off the 7e?
Can you be more specific about "hardware.ini is corrupt"? Can you open it but the contents are wrong? Is there an error message when you open it?
30 Oct 2016 18:17 #55530 by Birrel
Replied by Birrel on topic Corrupt hardware.ini
hexfet wrote: Does this consistently happen every time you power off the 7e?
Not every time, but only with power off for a longer period of time. I have used the devo for some time today, without any problems. I'll check tomorrow.
I can open the hardware.ini file with Notepad++, but it's emty. I'll post a screendump when it happens again.
02 Nov 2016 18:53 #55624 by Birrel
I quoted out "enable cyrf-6936" and leave the battery box unconnected. The last days the tx is working without any problem.
Time to create page: 0.419 seconds
