Devo10 Timer Alarms after upgrade to deviation 5.0
06 Feb 2017 03:18 #58796 by karla
I am a very happy user of deviation on my Dev010 transmitter (installed 4.0 long ago).
This weekend I finally upgraded to version 5.0. Followed the instructions and had no issues at all. I copied back my Model files from a backup. Also worked fine. However, I noticed that the different Timers are still there correctly but the Alarms (the buzzing sounds) are not.
How can I get the alarm sound back when, for example a countdown timer reaches 0?
Thanks a lot!
Karl
07 Feb 2017 07:46 #58856 by karla
... Just want to add the Buzz volume is set to 10 on the transmitter.
And also tried making new models and add a Timers with countdown function, but it just do not want to beep when reach 0.
Thats pretty serious ... like the whole point to tell when the time is up without taking your eyes off of the Heli. Agree?
Any ideas?
07 Feb 2017 07:49 #58857 by FDR
Do you have a proper sounds.ini file in the media folder, and has that sound settings for the appropriate timer event?
07 Feb 2017 07:51 #58858 by FDR
...also do the other sounds work, for example when you turn the TX on?
07 Feb 2017 08:23 #58860 by karla
Thank you for the reply.
No sound what so ever from the TX. I usually made a beep when power on.
But not now.
I have not checked any sound.ini files since I just assumed they would be uploaded in version 5.0.
How to check if such file is proper or not?
07 Feb 2017 08:46 #58861 by karla
Here is a screen shot of the file details and name and contents
Look very proper to me...
07 Feb 2017 08:54 #58862 by FDR
Looks proper.
Can you check the line ends if it is LF (i.e. Linux style as it should be) or CRLF (i.e. Windows style which is wrong)?
However is that the content of your TX's USB drive?
There shouldn't be zip, dfu, exe and dll files on the TX.
07 Feb 2017 09:14 #58863 by karla
oh,
Yes, if you look at the picture I uploaded I think all those files are there - to the way left.
Sorry I dont know how to check the LF at the end but I have uploaded the file here so maybe you can be kind enough to check for me?
Best
K
File Attachment:
File Name: sound.ini
File Size:1 KB
07 Feb 2017 11:50 #58870 by FDR
The file is fine.
Try to recreate the filesystem from a fresh download, but don't forget to backup xour model files and icons...
You dont need to copy the zip, dfu, exe and dll files, but only the tx.ini, hardware.ini, errors.txt and datalog.bin file, plus the folders of course...
08 Feb 2017 10:10 #58915 by karla
Thanks a lot FDR
- I copied the files you specified from a fresh download and now startup and timer sounds are all working :) :P :P
karla
Time to create page: 0.165 seconds
