DEVO 7E TURNS OFF WHEN BINDING
- jasonlove199450
21 Feb 2017 22:27 - 21 Feb 2017 22:31 #59416
by jasonlove199450
DEVO 7E TURNS OFF WHEN BINDING was created by jasonlove199450
My devo 7e seems to turn off when it binds to my tiny whoop.. I own a frsky d8 furibee f3 flight controller and I have a modded devo 7e modded with the cc2500 module.ONLY. I have tried ALL of the nightly builds and the Version 5.0.0. everything seems to work find until I try bind to my flight controller. when I click bind it seems to bind but as soon as it binds the lights go off on my flight controller and on my devo 7e. I know it isn't the flight controller causing the problem as I have also tried to use an external ppm frsky receiver soldered to my furibee f3 flight controller with the same result but this time only the external receiver goes off not the whole flight controller. By goes off I mean it doesn't come back on until I remove the battery to my flight controller and plug it back in and my transmitter just reboots its self. I have tried different batteries with my flight controller and with my transmitter just in case there was a power issue. I have added a photo of the wiring diagram i used to wire the cc2500 module Sorry for poor grammar I have dyslexia.
Last edit: 21 Feb 2017 22:31 by jasonlove199450.
- aMax
22 Feb 2017 01:00 - 22 Feb 2017 01:04 #59427
by aMax
Replied by aMax on topic DEVO 7E TURNS OFF WHEN BINDING
Seems as if the wrong wiring on this picture will live forever.
Read the thread, the solution is probably there. ( GDO0/2 & Pa/Lna pins & Vcc/Gnd)
www.deviationtx.com/forum/3-feedback-que...modules-cc2500#57848 [/quote]
Last edit: 22 Feb 2017 01:04 by aMax.
- jasonlove199450
22 Feb 2017 13:57 #59455
by jasonlove199450
Replied by jasonlove199450 on topic DEVO 7E TURNS OFF WHEN BINDING
I'v tried that . The transmitter doesn't go off now but both the receivers go off when it binds :/ I'v even tried another quadcopter (210 size) with the same problem
Time to create page: 0.191 seconds
- DEVO 7E TURNS OFF WHEN BINDING
