cannot install deviation
- enordaton
23 Feb 2017 13:45 #59523
by enordaton
cannot install deviation was created by enordaton
Just got a Devo 7e . My laptop HP Pavilion dv7 with W10 home does not see the Tx when connected to usb. Tried 2 seperate cords. Holding Ent and turning Devo7e on. Have Dfuse drivers installed and latest Dev5.0. What is next step?
23 Feb 2017 14:59 #59525
Replied by FDR on topic cannot install deviation
To switch into the DFU mode you need to turn on the TX while holding the 'EXT' button pressed.
The ENT goes into the USB mode, but it only works if you already have deiation installed...
- enordaton
23 Feb 2017 19:46 #59536
by enordaton
Replied by enordaton on topic cannot install deviation
Thanks for reply. The upgrade button is not active cannot click on it after opening dfu file. Stuck again.
- RobC62
23 Feb 2017 22:54 #59540
by RobC62
Replied by RobC62 on topic cannot install deviation
check in your windows device manager for any new USB items when you connect the Devo. I have to manually install the relevant driver to get Dfuse hardware to show. (HP Pavilion g6 running Win10) Until that is done, your Devo will not show in the Dfuse tool and the upgrade button will remain inactive.
- enordaton
24 Feb 2017 03:56 #59551
by enordaton
could not get this to work.used other method.installed java to use Deviationupload-0.8.0jar app. first attempt filled the memory to overflow,had to format drive and repeat installation.
- maxim10
24 Feb 2017 15:34 #59565
by maxim10
Replied by maxim10 on topic cannot install deviation
I think it has something to do with win10 I had the same trouble. It works with method.installed java to use Deviationupload-0.8.0jar app.
On the other hand I have problems to find a modell config for my Drones, I have XK X250, hubsan x4 501 and hubsan x4 107c.
Can somebody help!
Thanks in advance.
Lutz
Can somebody help!
Thanks in advance.
Lutz
24 Feb 2017 19:05 #59575
Replied by mwm on topic cannot install deviation
Did you try the ones at
www.deviationtx.com/wiki/model_config
Time to create page: 0.121 seconds
- cannot install deviation
