DEVO10 - PPM and TX Power Bug
- eakar
02 Mar 2017 14:38 #59769
by eakar
DEVO10 - PPM and TX Power Bug was created by eakar
Hi, I am new to DeviationTx and I noticed with my DEVO 10 today that Tx Power is always 150 mW while just PPM/USBHID mode active ist. The battery lasts longer when I fly with my toys instead of playing SIM. It mustn't be in like that. I changed ini files in Model Folder, but nothing changed.
It is very very waste of battery for me. Is there any solution?
best regards
best regards
- Moeder
02 Mar 2017 15:43 #59771
by Moeder
Replied by Moeder on topic DEVO10 - PPM and TX Power Bug
The RF modules are not enabled in PPM/USBHID, so no matter what the power setting is, there is no RF output and as such no battery wasted.
- eakar
02 Mar 2017 16:16 #59773
by eakar
Thanks for your fast answer. But I have no explanation for fast battery drain. I use 8 * duracell 2500 mAh battery. I also noticed that battery voltage is not true as devo 10 tells.
Replied by eakar on topic DEVO10 - PPM and TX Power Bug
Moeder wrote: The RF modules are not enabled in PPM/USBHID, so no matter what the power setting is, there is no RF output and as such no battery wasted.
Time to create page: 0.291 seconds
- DEVO10 - PPM and TX Power Bug
