devo 12e wont power on
31 Mar 2017 01:18 #60963 by nathaniel52441
devo 12e wont power on was created by nathaniel52441
attempted to install deviation firmware on my devo12e and I had to use the walkera software because deviation upload wouldn't recognize the transmitter even with the right driver. So the upgrade succeeded but when I turned it off and then on the screen was blank even while pressing the ext or ent key. Anything would help because it definitely feels like its bricked...
31 Mar 2017 08:54 #60973 by DIGGIDY
Replied by DIGGIDY on topic devo 12e wont power on
This sounds like library has not been installed.
After installing the dfu with the DfuSe tool, did you power down and bacj up again in USB mode to copy the library over?
In the user manual it states too..
Turn off the transmitter, and turn back on while holding ‘ENT’. There should be a USB logo on the screen. If this is a first-time install of Deviation, the PC should prompt to format a drive. Format using default options. Next, upgrade the file system via USB.
Read "2.2. DFU Installation With Walkera DfuSe" and "2.3. Upgrading the file system via USB" of the manual and try again.
31 Mar 2017 11:47 #60976 by nathaniel52441
Replied by nathaniel52441 on topic devo 12e wont power on
I tried to boot it'll USB mode as the instructions stated but nothing happens, the screen won't even light up anymore.
31 Mar 2017 11:51 #60977 by nathaniel52441
And also what library files are there in the devo12e nightly builds? It doesn't have any of the files that the guide suggests
31 Mar 2017 13:11 #60980 by DIGGIDY
Ok, lets make sure you got the correct build first.
This is the link to the 12e nightly build
deviation-devo12e-v5-0-0-9aa657c-zip
I've extracted this file and can see all the files required present.
31 Mar 2017 13:17 #60981 by nathaniel52441
Yes that's the version I had but it only had like 3 single files in it. I'm at work right now so I'd have to see what the file names were when I get off. I judged tested again this morning trying to enter DFU and USB mode, neither of them worked. No beep, no screen light.
31 Mar 2017 13:20 #60982 by nathaniel52441
I just downloaded that file you linked and it has way more files than the one I downloaded. Really odd
31 Mar 2017 13:50 #60984 by DIGGIDY
I have a feeling that you downloaded F12E which does have far less files.
31 Mar 2017 14:54 #60985 by nathaniel52441
I could swear that I didn't but it's entirely possibly that I did since I was tired. Would that firmware brick it? If not then I could easily flash the correct version if my receiver would just turn on. I've already checked the voltage conning from the battery pack connector and it is working fine.
31 Mar 2017 16:54 #60987 by DIGGIDY
Just re-flash the firmware, no harm would have come from using the wrong version.
31 Mar 2017 16:56 #60988 by nathaniel52441
It won't power on and the computer doesn't recognize that it's plugged in so I can't re-flash it, that's my main issue.
31 Mar 2017 17:37 - 31 Mar 2017 17:40 #60990 by DIGGIDY
Ah right, I see now.
Ok, remove/unplug the battery from the tx for 15 mins, make sure the battery is fully charged regardless of what voltage your measured, then plug it back in and then switch it on while pressing the EXT button, it should go into program mode.
If it's still not working I don't know what else to suggest, perhaps someone else on here has had a similar issue like this?
Last edit: 31 Mar 2017 17:40 by DIGGIDY.
31 Mar 2017 17:43 #60991 by nathaniel52441
I tried that this morning and it didn't work. I tried searching for users with a similar issues and couldn't find any :/ I'm not sure where to go from here other than buying a new one or seeing if UC drone will replace it.
31 Mar 2017 17:54 - 31 Mar 2017 17:56 #60992 by DIGGIDY
I would leave the battery out for a few hours or overnight as a last ditch attempt, or try putting some normal AA batteries in, everything I've read suggests it's the thing to do.
What part of the world are you from?
Last edit: 31 Mar 2017 17:56 by DIGGIDY.
31 Mar 2017 17:59 #60993 by nathaniel52441
I'm actually using AA right now and I left it unplugged last night figuring that might solve it but no dice.
I'm from the central USA
31 Mar 2017 18:00 #60994 by Moeder
Replied by Moeder on topic devo 12e wont power on
All possible solutions can be found in this thread
31 Mar 2017 18:14 #60995 by nathaniel52441
Awesome thread! Thank you for that, it looks like I need to flash my boot loader, already bought the programmer for it so hopefully this will fix it!
03 Apr 2017 20:02 #61137 by nathaniel52441
I tried flashing the bootloader but it didn't fix it, the flash worked but still nothing from the screen and no response on the USB port. I suspect it's because it's the Devo 12 bootloader not the 12e bootloader but that's all they had on the deviation bootloader page, any idea where I can find the Devo 12e bootloader? I tried searching google but didn't find anything, any help would be greatly appreciated
03 Apr 2017 20:05 #61138 by FDR
Replied by FDR on topic devo 12e wont power on
Rather try the DEVO 10 bootloader.
That's the most similar to the 12E...
03 Apr 2017 20:06 #61139 by nathaniel52441
I'll give that a try tonight after work, any ideas if that doesn't fix it?
Time to create page: 1.993 seconds
