usb driver
- clockman10
01 Apr 2017 16:58 #61026
by clockman10
usb driver was created by clockman10
can not install correct usb driver for devo7e transmitter dfu upgrade tool dfu does not find xmitter
- aMax
01 Apr 2017 18:27 #61028
by aMax
Replied by aMax on topic usb driver
"EXT" pressing at power on?
- clockman10
02 Apr 2017 14:14 #61070
by clockman10
Replied by clockman10 on topic usb driver
do that but xmitter does not find connect to computer
- clockman10
02 Apr 2017 14:16 #61071
by clockman10
have been trying to upgrade xmitter for many months still cannot connect to update program
- clockman10
02 Apr 2017 14:19 #61073
by clockman10
also have UP02 adapter it will not connect either
- clockman10
02 Apr 2017 14:40 #61075
by clockman10
finally got xmitter to connect but can not find upgrade files on my computer
- racer26
22 May 2017 20:41 #62498
by racer26
Replied by racer26 on topic usb driver
seems im having the same issues. i cant get my 7e to connect to the computer. how were you able to get it to connect?
- clockman10
23 May 2017 19:48 #62509
by clockman10
I held the ext button and turned on the xmitter it connected but will not update
- Deal57
24 May 2017 00:02 #62520
by Deal57
I've done this a few times recently because I'm messing with other STM devices. YMMV.
Replied by Deal57 on topic usb driver
- Uninstall Defuse completely and reboot.
- Use Device manager to view hidden USB devices and remove any drivers.
- Install Defuse 2.31.
- Open the Device Manager and connect your Devo. If the driver is correct it will show up as "STM Device in DFU mode" under Universal Serial Bus Controllers, and Defuse will see it.
- If it's not right, Device Manager will see "STM32 DFU" under Universal Serial Bus Devices, but you can then right click on the device, select Update Driver Software, select Let me pick...choose Universal Serial Bus Controllers, and select STM Device in DFU mode. This should allow Defuse to see the Device.
- clockman10
24 May 2017 13:43 #62526
by clockman10
not my problem problem is defuse can not find the library files to update xmitter
- racer26
24 May 2017 18:48 #62529
by racer26
Thanks for the help. That solved my problems.
- clockman10
26 May 2017 13:42 #62564
by clockman10
that's great where do you find the library files to download for the upgrade
- ketsa
30 May 2017 18:06 #62705
by ketsa
Replied by ketsa on topic usb driver
I noticed my Devo 7e is very picky when it comes to USB cables...
Some work, some just don't.
- clockman10
30 May 2017 19:00 #62706
by clockman10
I have no problem with connecting to USB just can not find the necessary files to upgrade transmitter
- racer26
30 May 2017 19:04 #62707
by racer26
They were in the file I down loaded from the deviation website. Then you have to unzip the files. Once you've done that you should be be able to find the file where ever it was down loaded. I'm only good enough to be dangerous with computers so it was a lot of trial and error for me, and I'm probably not the best person to be giving advise.
Time to create page: 0.808 seconds
