Failsafe below -125
- mario123
30 Apr 2017 19:51 #61880
by mario123
Failsafe below -125 was created by mario123
I wanted to set an throttle failsafe below -125 but it's not possible via the transmitter nor if I edit the model file.
I need it because my normal rates go down to -129
Any tip for me?
Regards
Any tip for me?
Regards
30 Apr 2017 20:07 #61881
Replied by FDR on topic Failsafe below -125
Just to clear things: how and why do your normal rates go down to -129?
- mario123
30 Apr 2017 20:23 #61882
by mario123
Replied by mario123 on topic Failsafe below -125
Because my betaflight is unhappy if it only goes down to -100 , because this equals 1100-1900 and betaflight likes higher values
But maybe I'm just to dumb to configure betaflight? Maybe that the cause of the problem
- Deal57
30 Apr 2017 20:35 - 30 Apr 2017 20:36 #61883
by Deal57
Replied by Deal57 on topic Failsafe below -125
This is a normal situation in both CF and BF. Use the rxrange command... if you search this forum there are a few threads with more details.
Start here: www.deviationtx.com/forum/3-feedback-que...sm2-not-bindin#61682
Last edit: 30 Apr 2017 20:36 by Deal57. Reason: Add URL
- mario123
30 Apr 2017 20:43 #61885
by mario123
Thanks for the tip will read later
Another thing I just noticed, I'm using an orangerx, the smallest steps in the bf receiver tab, I can get from my sticks are like 13 us second steps. Is this normal?
- Deal57
30 Apr 2017 20:57 #61886
by Deal57
I have an OrangeRX too on a Cleanflight quad... well, it's my grandsons. If he'll will let me I'll get some numbers!
- mario123
30 Apr 2017 21:05 - 30 Apr 2017 21:05 #61887
by mario123
Thanks would be great to see, has he got a Devo? Maybe I could get his model.ini? And his betaflight dump
So I could take some inspiration, because I'm about to throw all of the crap out my window.
Last edit: 30 Apr 2017 21:05 by mario123.
- Deal57
30 Apr 2017 21:24 #61888
by Deal57
I think
this thread
will cover most of the material you need. Let me know which transmitter you have and I probably have an ini with this integrated.
- mario123
01 May 2017 08:30 #61896
by mario123
It#s an devo 10, but i could copy some parts from the .ini files even if it's a tx
- mario123
01 May 2017 09:00 #61897
by mario123
You are my hero, my savior of the quad
I finally understood what rxrange meant, what it does and when to use it, thanks to your link
Time to create page: 0.101 seconds
- Failsafe below -125
