LemonRX range issue
15 May 2017 21:19 - 16 May 2017 12:19 #62328 by mario123
LemonRX range issue was created by mario123
I have an lemonRX satellite which should work with dsmx. I'm getting very little range approximately 20m with a tx power of 150mW.
Before that I used am orangerx ppm receiver and it gave me a much better range more than 100m, haven't fully tested it.
What could be the issue?
I'm running an devo10 powered by an 2s LiFePo with Deviation v5.0.0-db496d9
I will update it to the latest nightly, but I think it might be more of an issue with the bind procedure.
I used betaflight with the command set spektrum_sat_bind=9, which should be dsmx?
Greetings
Mario
Last edit: 16 May 2017 12:19 by mario123.
16 May 2017 13:40 #62358 by mwm
Replied by mwm on topic LemonRX range issue
The most likely possibility is that the two reverse engineered version of DSM aren't happy with each other. Try DSM2 instead of DSMX, and make sure you're using at most 6 channels as the reverse engineered implementations tend to go wonky with more channels.
Next is that something has broken in the nightly build. If that's the case, you might get a fix in the latest nightly, then again you might not. So try going back to 5.0.0 - either the release or VLAD's version with updated protocols.
16 May 2017 14:52 - 16 May 2017 14:56 #62363 by mario123
Replied by mario123 on topic LemonRX range issue
Ok i'll try dsm2 now. Can you give me a source for vlad's builds I wasn't able to find them?
Edit: Is this the page to download vlads releases? www.deviationtx.com/downloads-new/category/398-deviation-5-0-0
Last edit: 16 May 2017 14:56 by mario123.
16 May 2017 15:22 - 16 May 2017 15:38 #62364 by mario123
No change this time I even had a failsafe when the copter was hovering one meter away from me
By now I think the satellite is faulty, I'll throw another satellite in to see if that helps
Last edit: 16 May 2017 15:38 by mario123.
16 May 2017 21:04 #62371 by mwm
Vlad posts his builds on a thread in the forum. The latest build is at www.deviationtx.com/forum/builds/6407-de...cols?start=200#62154 , but you'll want to watch that thread for updates.
16 May 2017 21:36 #62373 by mario123
Ok thanks for the link.
I threw an redcon satellite in, and the range is nice, haven't had a single failsafe in my test area yet, so the lemonrx sat seems to be a lemon. ;)
Seems like the lemonrx is faulty.
Or there was a mistake while binding it who knows, I'll try again some time
Time to create page: 0.118 seconds
