Add toggles to Devo 12S
- jejeg
30 Jun 2017 17:42 #63223
by jejeg
Replied by jejeg on topic Add toggles to Devo 12S
Yes it works, i am under windows10
Your new dfu file is in your disk "E" MK ......
- magic_marty
30 Jun 2017 18:04 #63224
by magic_marty
Replied by magic_marty on topic Add toggles to Devo 12S
Yes works on Win 10 ..make sure all the files are on the usb drive (media ,scripts and the MkDevo12lid.exe) one thing that happened to me when i was having problems was the media folder was inside another media folder once i removed it and placed it directly on the usb drive it worked..saidem wrote: I still can not see the .DFU file created. I did it on a USB stick, it's the same. Yet the hidden files option is disabled on my computer.
And does it work with Windows 10?
Here is the picture below, is it good?
- saidem
30 Jun 2017 20:07 - 30 Jun 2017 20:16 #63226
by saidem
Replied by saidem on topic Add toggles to Devo 12S
Thank you all three is really nice.
I tried it again and I followed your advice, but I still do not see this .DFU file. Maybe you have another version than mine of the mklib program, I took it here, See photo below.
Can be a track, I do not have the scripts file, where to find it?
Last edit: 30 Jun 2017 20:16 by saidem.
- jejeg
30 Jun 2017 20:21 #63227
by jejeg
Have you tried your media file in an emulator?
Example:
# Deviation-emu_devo12-v5.0.0-ef04024
#filesystem
# devo12
# You change the media file by your modified media
# You memorize
# You go back on the emulator and test if it works
good luck
Example:
#filesystem
# devo12
# You memorize
good luck
- saidem
01 Jul 2017 06:49 #63230
by saidem
Before doing this you could send me your "mklib" program. You may have another version than mine. Thank you
- jejeg
01 Jul 2017 16:55 - 01 Jul 2017 16:57 #63234
by jejeg
Hi
To test in the emulator, you do not have to convert it into the Mklib tool
My new file média
My new file média
Last edit: 01 Jul 2017 16:57 by jejeg.
- saidem
01 Jul 2017 19:13 #63235
by saidem
I just tried with the emulator, I added in "media" files toggles 3,4,5,6,7.bmp. I can see them in the "media" directory after closing it and opening it. But the new toggles do not appear in the emulator.
Tomorrow I will try with the mklib file you sent me.
Thank you very much for helping me.
- jejeg
01 Jul 2017 19:32 #63236
by jejeg
If in the emulator it does not work, it will not work after having modified it with the tool MKlib
Do you respect the format of the toggles?
- saidem
02 Jul 2017 10:40 #63246
by saidem
I tried your MkDevoLib, and it is does not work.
I tried with emu 5.0.0 and all the files.bmp higher than toggle3.bmp do not work. If I replace the contents of the toggle3.bmp with my new toggles, I see them appear. Even the additional toggles in gray color if they are renamed to "toggle4.bmp" disappear. I think this is so due to a software version, because both TX and emulator are in 5.0.0. What do you think?
Could you send me your emulator version or tell me how I get it because I suppose it is a nighty?
Thank you very much
Thank you very much
- Deal57
02 Jul 2017 12:02 - 02 Jul 2017 12:10 #63247
by Deal57
Replied by Deal57 on topic Add toggles to Devo 12S
I thinking the Deviation code only supports Toggle3.bmp, not any others. I am sure there was a discussion some years ago over this code. On the larger screens it would sure be nice to have a few more choices.
Here is the thread from a few years back.
I also found that if you have a Toggle3 with more than 63 icons (on my 6s - so probably also other color screens), it displays only the first 63, then wraps back to the first one (on the choices you see more than 63, because you also have the ~30 in the other toggle files).
Last edit: 02 Jul 2017 12:10 by Deal57. Reason: Add link to discussion thread.
- saidem
02 Jul 2017 19:21 - 03 Jul 2017 09:24 #63250
by saidem
Deal57, I found a post that which confirms what you say.
Jejeg I attach the file with my toggles so that you try, because I have different answers you tell me that it works and I would like to know whether or not the files superior to toggle3 work.
Thank you.
Thank you.
Last edit: 03 Jul 2017 09:24 by saidem.
03 Jul 2017 04:53 #63254
Replied by vlad_vy on topic Add toggles to Devo 12S
Now you can use "mymedia/toggle3.bmp" with both "Nightly builds" and "v5.0.0 with latest protocols" build.
- saidem
03 Jul 2017 08:31 - 03 Jul 2017 08:48 #63256
by saidem
HI Vald-vy,
You wrote "Now you can use" mymedia / toggle3.bmp "but where use it and how I am a little lost, because at the start of the thread we were talking about TX USB drive, but in fact I think you Should be on the emulator?
I downloaded version 5.0.0 on March 26, 2017, should I install it again to run my "toggle3.bmp"?
To summarize my problem, the "toggle3.bmp" works with the emulator, but not with my TX because I still can not generate the new file.DFU to get it into my TX.
Now what do I do to solve this problem?
Last edit: 03 Jul 2017 08:48 by saidem.
03 Jul 2017 09:25 #63258
You can download latest Nigthtly Build or "v5.0.0 with latest protocols" build (starting from 2017-07-01), create "mymedia" folder at Devo 12 filesystem and write "toggle3.bmp". It will work now.
www.deviationtx.com/downloads-new/category/760-2017-07-03
www.deviationtx.com/forum/builds/6407-de...cols?start=200#63231
- saidem
03 Jul 2017 11:42 #63259
by saidem
Thank you,
But the file 5.0.0 still has the same update date "April 30, 2016" is this normal?
I have to create the files in the USB drive of the TX, is that what it is?
And after will there be need to remake the .DFU file?
- Moeder
03 Jul 2017 15:08 - 03 Jul 2017 15:09 #63263
by Moeder
Replied by Moeder on topic Add toggles to Devo 12S
Vlad was referring to his updated 5.0.0 build which can be found in
Vlads thread
. Although technically it is actually rather a nightly build without voice feature and gui changes, but don't worry, about that, either his or nightly build should work fine.
Last edit: 03 Jul 2017 15:09 by Moeder.
- jejeg
03 Jul 2017 19:47 #63269
by jejeg
I may not be all inclusive but this is not in usb mode but with the switch "trainer and then turn on the tx.
saidem wrote: I have to create the files in the USB drive of the TX, is that what it is?
- Wene001
03 Jul 2017 21:01 #63271
by Wene001
Replied by Wene001 on topic Add toggles to Devo 12S
hold the ent button and turn on
- saidem
04 Jul 2017 16:17 #63284
by saidem
Do not worry, all your comments are welcome. I think updating the .DFU files, but must do both (program and lib). And if so, can I update the .DFU of the program without updating the .ini files (Tx, Hardware).
What do you think?
What do you think?
- saidem
06 Jul 2017 10:20 #63318
by saidem
So I put the last nighty version, the library file and created the "mymedia" directory and put the new toggle3 in and everything works perfectly. I do not have the same menu presentations by the green arrows in the top right. Now the screens are much simpler and easier to use because the submenus appear as a list. It's also better with the use of buttons.
A big thank you to Vlad_vy and to all. If someone can tell me what the name of this version is, simply do not put the old one by mistake.
Time to create page: 2.181 seconds
- Add toggles to Devo 12S
