- New 4in1 installed on Devo12E. Now what?
- alanfjr
29 Jun 2017 01:38 #63198
by alanfjr
New 4in1 installed on Devo12E. Now what? was created by alanfjr
I just successfully installed Deviation 5.0 and my new 4in1 module. All the standard protocols that came with my transmitter are working fine on the new module,IE:DEVO,DSMX,DSM2 etc. However I can't seem to get the new protocols from the other 3 modules to work. Is there something I need to do for the transmitter to get it to see the new modules? HELP! I am a new to this.
- Deal57
29 Jun 2017 02:15 - 29 Jun 2017 02:18 #63199
by Deal57
Replied by Deal57 on topic New 4in1 installed on Devo12E. Now what?
You need to edit the hardware.ini file. You can do that using the USB connection. Be sure you use Notepad++.exe so that line endings are kept correctly.
Search for the Devo12E thread and there is a lot of information there.
Happy Flying!
Happy Flying!
Last edit: 29 Jun 2017 02:18 by Deal57. Reason: Add URL
29 Jun 2017 03:38 #63200
Replied by vlad_vy on topic New 4in1 installed on Devo12E. Now what?
You need solder 3 wires from 4in1 to main board and edit hardware.ini.
See Devo 10 connections:
www.deviationtx.com/forum/7-development/...dule?start=940#55157
- alanfjr
29 Jun 2017 10:22 - 30 Jun 2017 11:37 #63204
by alanfjr
Replied by alanfjr on topic New 4in1 installed on Devo12E. Now what?
I soldered in everything correctly .What exactly do i edit in the hardware.ini ? Ihave the settings up on my computer screen. What do I add or take off. Here is a copy of my existing file that came w/ Deviation 5.0.... ;Only useful for transmitters with an after-market vibration motor
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A13
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
Last edit: 30 Jun 2017 11:37 by alanfjr. Reason: Edit
- MikefromGermany
29 Jun 2017 10:37 - 29 Jun 2017 10:55 #63206
by MikefromGermany
Replied by MikefromGermany on topic New 4in1 installed on Devo12E. Now what?
no one can answer that without knowing what exact connections you have made.
Post a picture of your wiring, so one can see what module is connected to what solder pad.
or describe the connections from module pads to TX pads (e.g. 2401 to B7, 7105 to A13, 2500 to A14) Use https://www.deviationtx.com/media/kunena/attachments/2662/IMG_1697sm.jpgthis picture for reference.
THEN one could make a proper ini for you, or tell what has to be written in.
Quick glance how it could have been done:
www.deviationtx.com/forum/6-general-disc...iation-fans?start=20
proper approach:
www.deviationtx.com/wiki/rf_module_insta...ion/enabling_modules
www.deviationtx.com/wiki/modulelist/4-in-1_module
flics preferred?
www.rcgroups.com/forums/showthread.php?2...setup-for-everything
proper approach:
flics preferred?
Last edit: 29 Jun 2017 10:55 by MikefromGermany.
- alanfjr
29 Jun 2017 20:05 - 29 Jun 2017 21:58 #63210
by alanfjr
Success!, I saved my hardware.ini in another location just for safety, then I deleted the file in my transmitter. Copied and pasted from the Devo 10 hardware ini. thread posts into the 12E file, via USB and "Ba-mm!" it worked!
PS:Attached is the file you will need to copy and paste for you new 4in1 module in your Devo12e or Devo10. Don't forget to save your old hardware ini.file in your transmitter first, just in case there is a problem.
Last edit: 29 Jun 2017 21:58 by alanfjr. Reason: Adding Devo 12E attachment hardware ini.
Time to create page: 0.695 seconds
