Devo 6s screen replacement
- quique65
17 Sep 2017 12:06 #64455
by quique65
Devo 6s screen replacement was created by quique65
Hello. I have a Devo 6s with a broken sreen module. Anyone knows if its possible to use another 2.8 screen module (arduino, raspberry) as a replacement?. Thaks in advance for your help.
- RoGuE_StreaK
18 Sep 2017 05:33 - 18 Sep 2017 05:36 #64470
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo 6s screen replacement
Is it just the LCD, or is the touch gone as well?
Hardware info is here; https://www.deviationtx.com/wiki/hardware/devo6
LCD driver is HX8347-D, found this one on aliexpress which may or may not work, I've pulled apart my 6 almost to the bare bones but I didn't go to the extent of pulling out the LCD, so I don't know what the LCD connectors are like.
https://www.aliexpress.com/item/CPT-2-8-inch-37PIN-SPI-TFT-LCD-Screen-HX8347D-Drive-IC-320-240-QVGA-No/32644597065.html
I don't know how the touch works, don't even know if it's a separate layer
Last edit: 18 Sep 2017 05:36 by RoGuE_StreaK.
- quique65
Time to create page: 0.074 seconds
- Devo 6s screen replacement
