S-Bus Protocol
- ZeXx86
18 Sep 2017 12:13 #64478
by ZeXx86
S-Bus Protocol was created by ZeXx86
Dear members,
I have a question for anyone that is technically more skilled in the communication of the receivers.
We want to implement support for the S-Bus protocol that can work with RX-SBUS receiver or any similar. Unfortunately it looks like it is a different from Futaba S-BUS implementation.
For this reason we would like to know what are differences in the protocol?
Thank you,
Spirit System developer
Thank you,
- victzh
22 Sep 2017 04:23 #64578
by victzh
Replied by victzh on topic S-Bus Protocol
Which specific receiver do you mean when you say "RX-SBUS"? Walkera RX-SBUS? How did you find out that it's different?
- ZeXx86
22 Sep 2017 06:24 #64582
by ZeXx86
Replied by ZeXx86 on topic S-Bus Protocol
Simply - because it does not work.
While all Futaba receivers and also all FrSky receivers are working properly.
Yes, it is Walkera RX-SBUS receiver.
22 Sep 2017 07:54 #64588
Replied by vlad_vy on topic S-Bus Protocol
Probably transmitter and receiver is not connected. What is state of Rx LED? What about PPM protocol?
- aMax
22 Sep 2017 09:53 - 22 Sep 2017 09:57 #64591
by aMax
Replied by aMax on topic S-Bus Protocol
Assuming the target is a quad with F3 mcu, test your receiver with none inverted signal setting on the FC uart.
Maybe they have setup this way because the F4 chips don´t have this option and need a hardware solution.
If your FC has a F4 mcu, make sure you are using the intended uart port.
Frsky and Futaba receivers have an inverted signal output..
Last edit: 22 Sep 2017 09:57 by aMax.
Time to create page: 0.207 seconds
- S-Bus Protocol
