IRangeX iRX-IR8M software issue
- Reddog
16 Feb 2018 15:45 #67533
by Reddog
IRangeX iRX-IR8M software issue was created by Reddog
I"m hoping someone can help me.
I've had this radio about a month and everything was working fine. Now when I try to turn it on all I get is a USB icon on the main screen. It wont load the deviation software. I'm no programmer and have limited knowledge of this software. If anyone can help I would greatly appreciate it.
Things I've tried:
-Changing the batteries
-Leaving the batteries out all night hoping to reset something.
-Connecting it to windows 10( It sees it as a usb drive but then wont open anything)
-I've attempted to download dfuse and drivers for my computer but id didnt seem to work.
Is there a user program I need first?
Here is a link to a video if it helps.
Things I've tried:
16 Feb 2018 15:59 #67538
Replied by vlad_vy on topic IRangeX iRX-IR8M software issue
Most likely transmitter filesystem damaged. You need format transmitter USB drive and copy filesystem from firmware archive. Use "Safely Remove Hardware" after writing filesystem.
www.deviationtx.com/forum/builds/7605-ir...uilds?start=20#67508
- Reddog
17 Feb 2018 05:07 #67552
by Reddog
Replied by Reddog on topic IRangeX iRX-IR8M software issue
You were right! Formatting the drive did the trick! Lost all my models but if that's the worst of it I'm happy!
Thank you so much!
Thank you so much!
17 Feb 2018 06:50 #67555
I'm always backup my model files and other Tx settings on a regular basis, just to be sure I could recover them at any moment.
- oldflyer
21 Feb 2018 16:13 #67664
by oldflyer
Replied by oldflyer on topic IRangeX iRX-IR8M software issue
How do you reformat the USB drive? My screen is black when I plug the USB cable--it will download ok. I have loaded 2.14 firmware successfully--after a few minutes the TX will stop working and then start running through the menu's non-stop. Where can I find the original IR8M program to reload. It was working ok.
- oldflyer
21 Feb 2018 19:28 #67670
by oldflyer
Reddog--how did you reformat your USB drive--I am having the same problem that you are having. Thanks!!
- Reddog
23 Feb 2018 03:57 #67702
by Reddog
It sounds like you might have other issues besides the one I had. Regardless:
With the controller plugged into windows via the usb cable, Hold the enter button down while turning on the controller.
This should illuminate a USB logo on the main screen.
It should come up in the drive menu as an external drive.
Right click on the drive and select format drive.
That's it...
I would suggest coping the folder to the desk top before you do that though just in case.
Here is the youtube video I watched explaining how to do it.
Go to about 4 min in.
Best of luck!
That's it...
Best of luck!
- oldflyer
23 Feb 2018 22:12 #67723
by oldflyer
Reddog--thanks for the reply. My TX's LCD will not light up and the USB will not appear on the computer screen as a removable disk. I believe that my TX has hardware issues. Bang good has suspended sales because of all the problems with the TX. I am glad that you got a good one.
Thanks again.
Thanks again.
- Reddog
24 Feb 2018 02:18 #67726
by Reddog
It sounds like your ext button is sticking. Does it make a clicking sound when you push it? If it is stuck then your screen when you power it up would be solid black and be in the transmitter would be in the wrong mode.
- maxx
07 Mar 2018 21:58 #67966
by maxx
Replied by maxx on topic IRangeX iRX-IR8M software issue
Bonjour tout le monde je vien faire la mis à jour et il affiche sa il un solution merci
- totophe63
19 Mar 2018 23:38 #68213
by totophe63
Replied by totophe63 on topic IRangeX iRX-IR8M software issue
hello
USB screen is lock when switch on ?? J dowload new firmware but same pb ?
anybody idea ?
anybody idea ?
20 Mar 2018 04:16 #68218
Try to use latest build, it has to be fixed.
maxx wrote: Bonjour tout le monde je vien faire la mis à jour et il affiche sa il un solution merci
- totophe63
20 Mar 2018 18:49 #68230
by totophe63
which one please ?
21 Mar 2018 04:23 #68233
I see only one:
www.deviationtx.com/forum/builds/7605-ir...uilds?start=40#68208
- totophe63
21 Mar 2018 20:51 #68250
by totophe63
it's Ok ! Thanks
- Deezyy2476
18 Mar 2019 08:13 #73407
by Deezyy2476
Replied by Deezyy2476 on topic IRangeX iRX-IR8M software issue
Time to create page: 0.592 seconds
- IRangeX iRX-IR8M software issue
