Memory Mod. On F7
11 Mar 2018 20:08 #68011 by Bisky
Replied by Bisky on topic Memory Mod. On F7
Are u using DfuSe USB upgrade tool?
When u connect the transmitter in EXT + ON does it say DEVO-F7 program update?
does the pc find
Devo F7 XMS + 4in1 module
11 Mar 2018 20:30 - 11 Mar 2018 20:32 #68013 by Quell
Replied by Quell on topic Memory Mod. On F7
No EXT + ON and I get a blank screen, a blue blank screen.
Yes I'm using the Dfuse USB upgrade tool.
Last edit: 11 Mar 2018 20:32 by Quell. Reason: More
22 Mar 2018 14:37 #68274 by Bisky
Did you get it working?
22 Mar 2018 14:46 #68276 by Quell
Nope as far as I can tell everything is correct with the XMS modification.
I am not very good with the computer so I am thinking that it might be a problem with the drivers and it won't reload deviation.
I only pad 30 dollars for the radio so I think I will just put it on Ebay as a parts radio and try to get my money back.
Unless you know someone who can use it.
22 Mar 2018 15:04 #68281 by Bisky
Do you get the Walkera defuse screen on EXT+ Switch ON?
22 Mar 2018 15:10 #68282 by Quell
No just a blank blue screen, but this time I just reassembled it and when I turn it on I got the deviation version 5.0 screen and the strange one line menu. I played in the menu for a minute and shut it off, and then when I turned it on I am back to only getting the dimm Deviation usb screen.?? Weird
I have another radio and I'm tired of messing with this damb thing...
22 Mar 2018 15:26 #68283 by Quell
No offense to you I'm at a dead end , thank you so much for your time and help!
22 Mar 2018 15:27 #68284 by Bisky
Hook it up to a computer, you should se a usb flash drive? If so, format it and copy files to it.
22 Mar 2018 15:30 #68285 by Quell
OK I will give it a try in a little bit.
22 Mar 2018 15:47 #68286 by Bisky
I think the XMS mod was successful, but because the new chip is blank the devo goes into usb mode because the files it need to run are missing...
22 Mar 2018 16:25 #68287 by Quell
I have a feeling that it's good also. I wish someone on here that is good with computers would install deviation for me ;)
My computer will not recognized the radio so I'm stuck until someone can definitely install deviation or not?
23 Mar 2018 08:15 #68306 by Bisky
on EXT+ON you get this screen?
on ENT+ON?
If so, probably I could help you with drivers via remote connection...
23 Mar 2018 11:34 #68307 by Quell
EXT and on and I get a blue screen but it's blank nothing like what you show, it's the same bright blue but it's just blank.
23 Mar 2018 14:56 #68308 by Bisky
Pleas make a picture, how you moded the lines to the SMT32.
23 Mar 2018 14:59 #68309 by Quell
OK I will get some pictures later today.
Time to create page: 1.892 seconds
