- IRangeX iRX-IR8M does not bind to DSM2 receivers
- mlangstr
16 May 2018 20:52 #69261
by mlangstr
IRangeX iRX-IR8M does not bind to DSM2 receivers was created by mlangstr
Hi there,
I've just received my Irx-ir8m to use along with my dx6i but I'm running into problems binding with any receiver.
I've tried binding with a wireless dongle (for simulators) and with a tiny 7x. They both bind fine with the dx6i but when I try to bind it with the Irange it get stuck after the countdown (unless I move the right stick or the enter key) I have had it bind to the wireless dongle once and once it did that it worked nicely.
I've tried all the dsm2 options but that doesnt seem to do the trick.
I've also updated the firmware to ir8m-v5.x.x-2018-05-14 but that doesnt make a difference.
the irange does bind to the supplied receiver without any issues.
Maarten
Maarten
17 May 2018 03:41 - 17 May 2018 03:41 #69265
Replied by vlad_vy on topic IRangeX iRX-IR8M does not bind to DSM2 receivers
DSM protocols binding wait stick move, it's for failsafe values you can enter at protocol properties. If you don't need failsafe simply move any stick after countdown.
Last edit: 17 May 2018 03:41 by vlad_vy.
- mlangstr
17 May 2018 11:13 #69274
by mlangstr
Replied by mlangstr on topic IRangeX iRX-IR8M does not bind to DSM2 receivers
Thanks Vlad that really helped.
I moved the sticks during the countdown and the receiver binded..
Then I made he mistake of turning the tx off and on again... and the signal was gone..
I thought that the on/off bug of the tx was solved with the second version but there seems to be some thing still wrong there. If I turn the TX off and wait 20 seconds and turn it on again everything is fine again.
That is a very workable workaround for me.
Thanks a lot for your help.
Maarten
Maarten
Time to create page: 0.279 seconds
