New help with 4in1 on Devo 7E
- DPyro
17 May 2018 15:38 #69279
by DPyro
New help with 4in1 on Devo 7E was created by DPyro
I have installed the 4in1 as per instructions but when it boots up it says missing modules cyrf6936. I tried binding to a CX-10 but all models seem to have an asterisk in front of them.
Here is my hardware.ini
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
;enable-a7105 = A13
;has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A15
has_pa-nrf24l01 = 1
; enable-multimod = A13- DPyro
- DPyro
18 May 2018 17:13 #69301
by DPyro
Replied by DPyro on topic New help with 4in1 on Devo 7E
So I opened up the transmitter and tested continuity and found a stray wire going from red to white was shorting out. Pins from 3-4 in picture above. On boot I get missing modules NRF24101 missing, checking the different models shows some without the asterisk now.
- DPyro
18 May 2018 23:14 - 18 May 2018 23:15 #69303
by DPyro
Not entirely sure what to do here. The center two pins on the 4in1 beep with the continuity checker, I think the top is ground and bottom is not used so I don't know if that's even an issue. Also made sure none of the other joints were shorting out. I think only the NRF24101 is not working which sucks as it's the main one I need working. I followed
this
guide.
Last edit: 18 May 2018 23:15 by DPyro.
- DPyro
20 May 2018 15:55 - 20 May 2018 15:55 #69338
by DPyro
An update since no one was able to help me. Two center pins on 4in1 are both ground so it makes sense they connect. I swapped wires soldered to CSN2401 and CSN7105 and my changes reflect that in the hardware.ini. Also after a lot of trial and error I was able to solder the 2nd pin on the STM32F103.
Here are my changes in the hardware.ini
;enable-haptic=1
;extra-switches=
;extra-buttons=
[modules]
has_pa-cyrf6936 = 1
enable-a7105 = A15
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = A13
has_pa-nrf24l01 = 1
Last edit: 20 May 2018 15:55 by DPyro.
Time to create page: 0.034 seconds
- New help with 4in1 on Devo 7E
