How Jumper t8sg plus bind Flysky AFHDS-2A
24 Aug 2018 19:06 #70435 by adji
Help
Hi... Master Drone..
I have Eachine Aurora 100 (Flysky).. n Jumper T8sg plus.
How a Jumper t8sg plus Bind Flysky AFHDS-2A ?
How Freq Fine?
Thanks...
I hope u ... Help me.
25 Aug 2018 23:57 #70455 by Suter
Replied by Suter on topic How Jumper t8sg plus bind Flysky AFHDS-2A
Good day Adji,
I have just bound one of these.
Switch on TX
1. Model menu
Enter
2. Model set up
Enter
Down key v
To left hand box below “PPM in”
Use < or > keys to find :- AFHDS-2A
Use v (down) arrow to bring curser to the bind box on the right side of AFHDS-2A
Leave curser sitting on Bind ready to press after you do A below
RECIEVER
I do not know the model receiver you have, but the receiver I bound had a very small bind button on one side. About the size of a pin head. I was able to push it down with my thumb nail.
The secret is to hold down the bind button while connecting the battery.
A: Hold down bind button while connecting battery.
1. If the receivers LED is flashing it has entered bind mode.
2. Press Enter button on TX.
3. If binding is successful the receiver LED will flash slower.
4. Manually exit the TX binding menu.
5. RX led will stop flashing and remain solid
6. Power down RX and then re connect.
You should be all bound and ready to go.
Hope I have helped
Cheers
W
26 Aug 2018 10:00 - 26 Aug 2018 10:01 #70458 by adji
Thanks at your solution...
I try ... But drone cant respon..
Is Bind... Green indicator ok.
And Not beep.. Beep lamp indicator.
What is setting in betacore is wrong??
Frimware omnibus 3.2.0 and i upgrade is firmware..
Last edit: 26 Aug 2018 10:01 by adji.
Time to create page: 0.591 seconds
