Devo F12E Fpv problem?
27 Aug 2018 12:06 #70475 by Stavross118
Devo F12E Fpv problem? was created by Stavross118
Hi Guys or Gals
Have a Devo F12E 4 in 1 module and voice module all working good the problem if any can help is my Fpv antenna snapped of at the module I have resoldered module terminal back on
But ever since this I have snowy picture and the transmitter switches off like there’s no power even though the switch is on but can switch off to on it works again....and if I use without Fpv on it seems ok and stays on ?
Cannot see any short in the antenna terminal or any bad solder joints ...does anyone know if the Fpv module can cause this problem or something else also tried finding a module replacement with no joy?
Any help would be great sorry if this is in the wrong place please move if so?
Stavross
I have checked and triple checked with continuity
29 Aug 2018 12:22 - 29 Aug 2018 18:32 #70521 by Stavross118
Replied by Stavross118 on topic Devo F12E Fpv problem?
Hi again
Not had any views yet on this?
So if any clever people out there ....as thought I would try this as a replacement fpv receiver looks similar pin out except more channels for fpv but was only thinking of linking upto channel 4 and only using the direct female pins on the daughter board to this module any thoughts on this and if it would work as better than a faulty one?and no help from Walkera as out of guarantee now!
Last edit: 29 Aug 2018 18:32 by Stavross118.
24 Apr 2019 15:18 - 24 Apr 2019 15:26 #74120 by 52dgj
Replied by 52dgj on topic Devo F12E Fpv problem?
I think you should successfully replace the original 5.8G module, this is my test module. JM201R(32CHANNEL) [attachment=11822]
Last edit: 24 Apr 2019 15:26 by 52dgj.
Time to create page: 0.296 seconds
