ini for blade inductrix BL?
30 Sep 2018 03:58 #71097 by dawsonmobley
ini for blade inductrix BL? was created by dawsonmobley
Got my brushless inductrix today and trying to get it working with devo8s.
Got the flight modes switch working but can't seem to figure out the arming? Channel 6 is supposed to be the arming channel and I understand it expects a momentary switch but I can't figure out how to make it work with a 2 position switch?
10 Oct 2018 23:51 #71272 by jasond
Replied by jasond on topic ini for blade inductrix BL?
did you get it to work?
11 Oct 2018 03:14 - 11 Oct 2018 03:14 #71281 by dawsonmobley
Replied by dawsonmobley on topic ini for blade inductrix BL?
jasond wrote: did you get it to work?
yes, used a ini for a regular inductrix and everything seems to be working. arming is a little odd but it works.
I used the ini in the first post of this thread .
Last edit: 11 Oct 2018 03:14 by dawsonmobley.
11 Oct 2018 15:25 #71287 by jasond
does the meow mode work? and are you able to change the light colors?
i am considering buying one but want to make sure it will work with my f12e first.
05 Mar 2019 23:32 #73226 by n8xyn
Replied by n8xyn on topic ini for blade inductrix BL?
Does anyone happen to have this ini to share?
Time to create page: 0.114 seconds
