Intermittant pulses from stick inputs
07 Oct 2018 18:41 #71216 by SteveB
Having trouble with a frsky receiver Using a T8SG Plus (Now my favorite TX and all the spektrums sit on the shelf). I can bind the radio and see reactions to input in Betaflight but have never got it to arm (switch arming). For whatever reason my inputs all work, but in 30 ms intervals. The throttle goes between 885 and 1260 (when left low) and the other inputs stay stable at 1500 but only bounce when moved. The screenshot below is BF with the throttle left low and the aileron held full right.
The blue line at the bottom represents the throttle and the orange line bouncing from center to high is the aileron. If I center all sticks the lines (inputs) all stay centered correctly and the CH5 and CH6 switches stay where I put them (the green lines on the top)
This transmitter is fantastic on five other receivers, all DMSX, but this is my first attempt to bind it to frsky.
Need Help, going crazy trying to figure out what is happening!
27 Nov 2018 16:42 #71903 by FatBoy
Replied by FatBoy on topic Intermittant pulses from stick inputs
Hello SteveB,
Looks like I have hit the same issue, "..can bind the radio and see reactions to input in Betaflight but have never got it to arm (switch arming) ..."
Still playing around the settings, and no clue how to fix it.
Just like to see if you had finally got it work, and possible to share your solution here.
Many thanks
27 Nov 2018 17:40 #71904 by SteveB
Replied by SteveB on topic Intermittant pulses from stick inputs
Haven’t figured this out yet. Have now bound my T8SG to other FrSky rx’s with no problem but I have two receivers that do this. Still trying to figure out why.
27 Nov 2018 19:30 #71905 by hexfet
Replied by hexfet on topic Intermittant pulses from stick inputs
What type of receiver has these symptoms? All the same? Any of that type that do work?
What is the receiver output format (pwm, ppm, sbus)? How many channels enabled in the model? Same issue with a freshly created model with default mixers?
Has the Freq-fine option been optimized with the problematic receivers?
27 Nov 2018 20:34 #71908 by SteveB
hexfet wrote: What type of receiver has these symptoms? All the same? Any of that type that do work?
They have all been integrated (on FC). Two that did work were from Banggood; the one on KingKong 125 and one on an E010. The ones that did not work were from BetaFPV betafpv.com/products/f4-brushed-flight-controller-frsky-rx-osd and the “SharkWhoop” from Banggood that says Lemon FrSky on it.
Sbus
Can’t remember but i think they both bound to the D8 mode with at least 6 channels enabled (4 + arm and mode switches) and more would be added if they worked.
Yes
No. Researched this a bit but a little out of my league.
27 Nov 2018 21:41 #71910 by hexfet
With integrated receivers especially try the Freq-fine setting. Adjust positive and negative in steps of 10 until bind is lost, then set to a value in the middle. Is there a receiver LED that indicates bound? It might start flickering when close to losing bind.
That said, the symptom of channel values not being stable doesn't sound like a frequency mismatch.
27 Nov 2018 23:25 #71913 by SteveB
No, I agree that it doesn’t seem to be an issue of poor reception. The results are very consistent and repeatable.
One thing I wondered about was the frequency hopping sequence; it’s as if the radio communicates, then goes to failsafe value, then repeats in quarter second intervals. However the receivers I have that work have identical hop list.
28 Nov 2018 02:18 #71915 by FatBoy
Answers to the questions,
I have two models , ELf Dys (stock frsky D8 ) and a BNF model with Queen SPR F3 receiver (I think it is)
They use SBUS, 8 channels. Binding works , all switches responsive showing in BF, no clue why the arming won't work.
I do not know if this is reception issue, I may go ahead to find the centre frequency as suggested. Thanks
02 Dec 2018 07:10 #71949 by FatBoy
I might figure out the fix with help from other forum.
The additonal setting required is to set the 'scale-' of THR to 125, in order to get it armed. I don't yet know the exact technical reason behind. Hope it helps
Give it a try, happy flying
Time to create page: 0.278 seconds
