Rssi and spektrum sat. 4649t
25 Nov 2018 13:08 - 25 Nov 2018 15:22 #71880 by defimaint
Rssi and spektrum sat. 4649t was created by defimaint
hello,
i have devo8s and deviation 5.0.0 , and controller card f405 sd matek
telemetry is volt is ok
but we don't have rssi, Amp, etc...
In betaflight 3.5 i see volts, Amp, but don't see RSSI
On the receiver devo 8s, i see volt, don't see AMP, and RSSI.
have you got solutions?
thanks
Last edit: 25 Nov 2018 15:22 by defimaint.
09 Dec 2018 22:47 #72035 by defimaint
Replied by defimaint on topic Rssi and spektrum sat. 4649t
hi
my Rssi is ok in the control card f405 matek!
i'm update my sat. 4649T with version 1.10.0 (2017). my old version was 1.01.0(2016).
use cable spma3065 spektrum and soft spektrum for update firmware
but i don't see in the telemetry devo 8s. is it possible? the same problem with the intensity , i see intensity in Betaflight . have you got solution for see this values.
thanks you
Time to create page: 0.270 seconds
