T8SG V2 PLUS failsafe issue
- lrxsmb
26 Jan 2019 16:03 #72542
by lrxsmb
T8SG V2 PLUS failsafe issue was created by lrxsmb
HI everybody!!!
I have a serious range issue with my jumper T8SG V2 plus...
Most of the time I've got failsafe (rxloss) at less than 100 meter with diversity flysky receiver (fli14+) same with other receiver even if my RSSI is 90+. Compared to my FS-i6 where I get at least 300m+ range.
Sometime I can't even arm my quad, RXLOSS alert each time I try to arm...
Quick video: https://youtu.be/wBVDmmqk_fs
As you can see rxloss at 0:05 with rssi at 95 and unable to arm multiple time at 0:15.
Any advice?
Thinkin it was a counterfeit radio after all problem I've got for flashin it...
Any advice?
- Fernandez
26 Jan 2019 18:35 - 26 Jan 2019 18:37 #72551
by Fernandez
Replied by Fernandez on topic T8SG V2 PLUS failsafe issue
you could try first try fine tune the frequency during bind? Just to check, that you are centered.
You could also monitor LQI indicator it is better and available in deviation.
If someone has a power meter, you can validate the output power.
but sounds very strange rssi 90, while fail saving couldn't be a power issue at the RX side?
Last edit: 26 Jan 2019 18:37 by Fernandez.
- lrxsmb
26 Jan 2019 19:17 #72553
by lrxsmb
Replied by lrxsmb on topic T8SG V2 PLUS failsafe issue
Already tested freq tune, stock tune doesn't look bad, when I success to bind I get signal from -200 to 200.
Already use LQI
Sadly no power meter.
No RX power issue, same issue on all my receiver (test with 3 different)
Already use LQI
- Fernandez
26 Jan 2019 19:50 - 26 Jan 2019 19:52 #72556
by Fernandez
I have to say the Flit12 diversity receiver I find it less range than the Flysky X6B, with Flit I had fail saves.
I own no original Flysky Tx to compare, but you should get same or maybe even bit better range at 150mW?
I get longer ranges with Frsky than Flysky.
Oh btw, Hexfet has been working recently on Power adjustments of the protocols, I do not hope there is a bug?
www.deviationtx.com/forum/7-development/...-nightly-build#72479
I bought a power meter, possibly can verify it....
www.aliexpress.com/item/8GHz-1-8000Mhz-O...5d-8bfe-b29a2799ca57
Last edit: 26 Jan 2019 19:52 by Fernandez.
- lrxsmb
27 Jan 2019 12:10 #72574
by lrxsmb
That's not a rx issue, tested with all my quadcopter, same with all !
And like I said I've got a loooooot more range with the fs-i6.
- lrxsmb
28 Jan 2019 15:29 #72582
by lrxsmb
No one???
Should I blow it with a firecracker?
28 Jan 2019 16:04 #72584
Replied by vlad_vy on topic T8SG V2 PLUS failsafe issue
You can try "Deviation v5.0.0 build with latest protocols" build, and we will know if it's software or hardware bug.
www.deviationtx.com/forum/builds/6407-de...cols?start=400#72350
You need perform full install, since this build use different filesystem.
- lrxsmb
28 Jan 2019 17:30 #72588
by lrxsmb
Thanks vlad!
I'm on "deviation-t8sg_v2_plus-v5.x.x-2019-01-23" but gonna give it a try!
- lrxsmb
28 Jan 2019 18:02 #72589
by lrxsmb
New firmware new bug...
28 Jan 2019 22:28 #72595
Replied by hexfet on topic T8SG V2 PLUS failsafe issue
Did you copy the filesystem files from vlad's build? There's some differences between 5.0.0 and nightly build.
29 Jan 2019 04:11 #72605
You can backup used models files and "tx.ini" and use it with v5.0.0 firmware.
- lrxsmb
13 Feb 2019 00:12 #72880
by lrxsmb
Hi !
Didn't touch her for some day...
Flash it with nigthly build, all look fine for some day... And back to some weird betaflight rxloss alarm with full rssi, failsafe and unable to rearm... Sometime yes... Sometime no...
Flash today with latest 5.0.0 you post vlad, same result.
Weird thing... Get better result when radio is vertical than horizontal... Moving antenna didn't change anything...
Maybe I've got a bad antenna ? Unfortunately didn't have an other one for test.
- Fernandez
13 Feb 2019 21:52 #72887
by Fernandez
Rx Loss with full RSSI ? Strange....
I can say deviation Tx has been really rock solid for me, so I would search for hardware issues loose connections bad soldering etc. Loose sbus line between Rx-Flight controller etc.
Time to create page: 0.047 seconds
- T8SG V2 PLUS failsafe issue
