Maximum number of audio files.
31 Jan 2019 12:52 #72645 by Ryou
Maximum number of audio files. was created by Ryou
The Voice file seems to be up to 400, but can not you increase it more?
I would like it to be 500 if possible.
31 Jan 2019 15:46 #72648 by Moeder
Replied by Moeder on topic Maximum number of audio files.
Yes, it is possible, it was only restricted due to limit memory usage. I'm in the process of reducing memory usage, so we could increase the file limit (although I really wonder if you need so many voice files...;)
01 Feb 2019 00:05 #72651 by Ryou
Replied by Ryou on topic Maximum number of audio files.
Yes.
We added 110 additional custom voice data.
Unfortunately only 45 additional items can be played in the current firmware.
Please increase the number of files to the extent that other functions are not affected.
Thank you.
03 Feb 2019 10:59 - 03 Feb 2019 11:07 #72684 by Moeder
Hi!
I would like to give you a test build with reworked voice.ini handling. Which transmitter do you need?
Last edit: 03 Feb 2019 11:07 by Moeder. Reason: added t8sg_v2 test build
03 Feb 2019 11:37 #72685 by Ryou
Moeder wrote: Hi!
Thank you Moeder.
I am using the T8SG_V2_Plus transmitter.
Please give me a test build.:cheer:
03 Feb 2019 12:09 #72686 by Moeder
here it is
03 Feb 2019 13:21 #72687 by yets
Replied by yets on topic Maximum number of audio files.
Moeder what does this new handling include?
03 Feb 2019 15:38 #72690 by Moeder
It is mostly background stuff and bug fixing. Most of the initial integration was pretty crude and not very efficient. Before diving into new features I wanted to clean up some stuff. As a side effect, getting voice features for 7e builds is very feasible now, as we are working on reducing ROM needs for 7e builds.
04 Feb 2019 01:47 #72699 by Ryou
Moeder wrote: here it is
Thanks for building the test.
Custom voice 400 and beyond are played but only numbers are displayed on the Voice Config screen. It is hard to use.
:cheer:
04 Feb 2019 06:17 - 04 Feb 2019 06:22 #72703 by Moeder
Please post your voice.ini for testing.
Edit: already found the bug, will post an updated build tonight. Besides this issue, is everything working as expected?
Last edit: 04 Feb 2019 06:22 by Moeder.
04 Feb 2019 07:39 #72705 by Ryou
Moeder wrote: Please post your voice.ini for testing.
If the number of Voice MP3 files is large, reading of the timer becomes short and it is abnormal.
Probably telemetry warning will also become abnormal.:(
04 Feb 2019 08:22 - 04 Feb 2019 09:06 #72709 by Moeder
Can you explain a little more or post a short video demonstrating this? Is it a gradually increasing issue with larger numbers?
Edit: reading the code again this likely the same issue as the labels, both should be fixed tonight.
Last edit: 04 Feb 2019 09:06 by Moeder.
04 Feb 2019 15:22 #72712 by Moeder
This should hopefully fix the issue, if now coded a limit of 999 custom files btw.
05 Feb 2019 00:35 #72715 by Ryou
Moeder wrote: This should hopefully fix the issue, if now coded a limit of 999 custom files btw.
Thank you Moeder.
I will check the operation after going home tonight. I think that the result will be in about 12 hours.
05 Feb 2019 10:09 #72721 by Ryou
There is no problem on screen display.
Audio playback seems to be shorter when there are many MP3 files.
Although the movie is the same sound file, the remaining 10 seconds is abnormal when the number of files is large.
Movie 1: Normal
Movie 2: Failure
These videos are examples. One minute reading aloud is also abnormal.
05 Feb 2019 22:24 #72722 by Moeder
Thanks for the videos. Is this issue increasing with higher file numbers?
06 Feb 2019 00:49 #72725 by Ryou
Moeder wrote: Thanks for the videos. Is this issue increasing with higher file numbers?
We are only testing with 264 custom Voice. It's tough to create files manually. I'm sorry.
06 Feb 2019 12:27 #72739 by Moeder
Try moeder.pythonanywhere.com/voicepacker/default/index
to easily create larger voicepacks
08 Feb 2019 13:25 #72816 by Ryou
I tried it with over 500 Voice.
The screen was not displayed properly.
10 Feb 2019 22:30 - 10 Feb 2019 22:30 #72849 by Moeder
I tested with the voice pack you created on voicepacker and it works fine here on my T8SGV2+. Only issue I noticed is that number announcements are cut of a little bit (tested with timers).
Last edit: 10 Feb 2019 22:30 by Moeder.
Time to create page: 0.775 seconds
