Jumper t8sg plus v2 voice and buzzer not working
30 Jan 2020 16:30 #75858 by Hans-Udo
Abbasciano wrote:
Whik123 wrote: Is there anyway i can get them both working properly again ?
Hello! Were you able to find a solution? I'm having the same problem as you.
I have the same issue, Did anyone solf this problem?
28 Mar 2020 09:39 #76118 by erich
Strange on my side both lines are ok in the hardware.ini file but I cannot get both voice and vibration at the same time.
Vibration only works if sound volume is disabled...
Any idea how to get both enabled?
05 Apr 2020 18:08 #76137 by aeQuator
Did someone make any progress on this? Mine came in yesterday and sound only yells "saveing, saveing, saveing, saveing......" at me.
I did all what was writen down, but still no succes.
06 Apr 2020 03:03 - 06 Apr 2020 03:05 #76142 by eried
aeQuator wrote: Did someone make any progress on this? Mine came in yesterday and sound only yells "saveing, saveing, saveing, saveing......" at me.
www.deviationtx.com/forum/7-development/...ice-some-other-fixes
Last edit: 06 Apr 2020 03:05 by eried.
06 Apr 2020 03:04 - 06 Apr 2020 03:05 #76143 by eried
erich wrote: Strange on my side both lines are ok in the hardware.ini file but I cannot get both voice and vibration at the same time.
This is buggy in the firmware. You could enable vibration but it keeps vibrating forever
06 Apr 2020 06:18 #76144 by aeQuator
Thanks for your reply, does it mean, i eather have to deal with it or solder something i'm not experience enough for?
Is there a firmware which can fix that?
06 Apr 2020 07:39 #76145 by eried
aeQuator wrote: Thanks for your reply, does it mean, i eather have to deal with it or solder something i'm not experience enough for?
Firmware cannot fix that. Next revision of the controller maybe includes the fix since I contacted jumper but who knows.
06 Apr 2020 09:51 #76147 by aeQuator
Okay, last question to be sure.
If i don't solder onto the board, there is no sound for me, because factory messed up?
06 Apr 2020 10:54 #76149 by eried
There will be sound but with that "saving saving saving" and also some other repetition of the same on DFU mode etc
06 Apr 2020 12:51 #76151 by aeQuator
Replied by aeQuator on topic Jumper t8sg plus v2 voice not working
yeah, as soon as i turn it on with sd card in.
06 Apr 2020 12:54 #76152 by eried
Replied by eried on topic Jumper t8sg plus v2 voice not working
Yes but it will work like that forever, but the voices should work after it boots. You probably have not copied the voice.ini to the remote (not the sd)
06 Apr 2020 18:10 #76157 by aeQuator
i did copy it to the tx internel space media/voice.ini.
Even after the boot it keeps yelling at me.
06 Apr 2020 18:30 #76159 by eried
That is not going to change. But the you should be able to assign voices to switches and such
07 Apr 2020 13:58 - 07 Apr 2020 13:59 #76162 by sansjunk
If you are not up to the soldering or can't find someone to do it you can replace the "0011_Saving.mp3" with a silent mp3. This is what I had done before @eried figured out the issue and posted the solution. Now I have applied the hardware fix though.
Last edit: 07 Apr 2020 13:59 by sansjunk. Reason: typo
07 Apr 2020 14:37 #76163 by eried
After a while the file changes to something else... like if the weather is humid the file is another one.
09 Apr 2020 12:19 - 09 Apr 2020 12:20 #76168 by sansjunk
eried wrote: After a while the file changes to something else... like if the weather is humid the file is another one.
Oh, I was not aware of that. Luckily where I live the weather isn't extreme so it was always the "Saving" file for me.
Last edit: 09 Apr 2020 12:20 by sansjunk. Reason: typo
09 Apr 2020 14:08 #76169 by aeQuator
I tried that with the silent.mp3 but that i had just not sound at all.
Something in the Firmware has to be wrong, why else should it trigger the sound in a constant matter, if the software is not telling to start, there should be not start?
I don't think a missing resistor is the reason for a not stoping sound, that must be software.
09 Apr 2020 17:17 #76170 by eried
It is hardware. I try to explain it in the video of the fix. I spend an hour trying to debug the firmware to find that it was the hardware.
09 Apr 2020 17:44 #76171 by aeQuator
i belive that, it's just that i can't understand it.
Why is a missing resistor looping sounds?
09 Apr 2020 19:02 #76172 by eried
I try to explain it in the video, but the short version is: there are special pins that support multiple buttons using a resistor ladder, but they forgot to connect them to something so they are "floating". The resistor just bridges those pins to ground so they dont trigger "saving, saving".
Time to create page: 2.291 seconds
