- Jumper t8sg plus v2 voice and buzzer not working
- aeQuator
09 Apr 2020 20:16 #76173
by aeQuator
Replied by aeQuator on topic Jumper t8sg plus v2 voice and buzzer not working
sorry for my stupidity, so like a short? Then it would be hardware yes.
- eried
09 Apr 2020 20:20 #76174
by eried
Replied by eried on topic Jumper t8sg plus v2 voice and buzzer not working
It is call pull down, but I think in this case a short to ground would work.
- Ariete
12 Sep 2020 18:33 #76777
by Ariete
Replied by Ariete on topic Jumper t8sg plus v2 voice not working
I received my Jumper T8SD Plus carbon and it doesn't make any sound at all. I wonder what good are alarms if I can't hear them.
Is this normal?
Also it came with a plastic piece marked as "Sound chamber DIY".
Does it means I have to tinker with it to add sound?
If yes, could anyone point me to the instructions?
Is this normal?
- propnut
12 Sep 2020 21:10 #76778
by propnut
Replied by propnut on topic Jumper t8sg plus v2 voice not working
It has the electronics for voice but no SD-CARD. You need to get an SD-CARD, a small one is fine, and follow the instructions outlined in the voice mod tutorial which you can find in the WIKI section. You need to download the voice files, put them on your SD-CARD, you then need to copy the sound.ini and put in on the main radio flash drive and you need to modify the hardware.ini file. Then your voice will work.
CAUTION !!!! Do NOT use a MAC, ONLY a windos machine. A MAC will corrupt your radio flash.
- Ariete
12 Sep 2020 22:56 #76779
by Ariete
Thanks, I will try that
- yammahoppy
14 Sep 2020 16:20 #76781
by yammahoppy
Replied by yammahoppy on topic Jumper t8sg plus v2 voice not working
What Propnut said. I had an issue but it was simply me not deleting one of the semi-colons in the hardware.ini file. If you follow the Wiki instructions all works. You will also have to tell the radio what sounds to use for each switch. All easy though.....
- Ariete
19 Sep 2020 16:52 #76798
by Ariete
I did that and everything is working fine.
I can select which voice is activated by which switch or timer or what ever.
- yammahoppy
20 Sep 2020 00:25 #76803
by yammahoppy
You have to go in the model setup at the bottom where it says voice. You then have to select each switch position and assign the speech you want.
- mtungate
19 Oct 2020 15:11 #76900
by mtungate
What exactly did you do to get your sounds to work. I just received the t8sg plus carbon and I also get no sound at all...nothing. I checked the .ini files and they seem to be fine.
Replied by mtungate on topic Jumper t8sg plus v2 voice not working
Ariete wrote: I did that and everything is working fine.
- propnut
19 Oct 2020 17:04 #76901
by propnut
The Carbon does not come with an SD-Card. You need to get one and then install then follow the instructions given in the wiki section in order to put the voice files on it and modify the relevant files.
- mtungate
19 Oct 2020 17:07 #76902
by mtungate
I didn't realize there was an SD slot. I followed the instruction, put in a card and it worked!! Thank you.
Time to create page: 0.130 seconds
