T8SG Lite ( Firmware )
06 Mar 2019 05:42 #73229 by old4570
T8SG Lite ( Firmware ) was created by old4570
Some one contacted me about factory stock firmware ...
Apparently they flashed V2 firmware into their Lite ..
I have a Lite , and can the firmware be Copied ( Ripped ) or is this guy stuck till someone releases a update ?
06 Mar 2019 07:00 - 06 Mar 2019 07:06 #73230 by vlad_vy
Replied by vlad_vy on topic T8SG Lite ( Firmware )
At least one user successfully flashed "t8sg_v2" firmware to T8SG Lite:
www.deviationtx.com/forum/6-general-disc...umper-t8sg-lite-hepl
P.S. Usually Jumper placed firmware *.dfu file to transmitter USB drive.
Last edit: 06 Mar 2019 07:06 by vlad_vy.
08 Mar 2019 23:55 #73276 by xandao
Replied by xandao on topic T8SG Lite ( Firmware )
I also have a lite, but he's in trouble. would you like to share the original files of your jumper? I updated with this V2 but it did not work
09 Mar 2019 01:47 #73277 by old4570
Replied by old4570 on topic T8SG Lite ( Firmware )
If there are instructions for copying the original firmware and saving it ...
I will give it a go !
I don't us my lite , simply because the gimbals bite ... ( That rhymed ! )
So , happy to give it a go ( ripping the firmware )
09 Mar 2019 16:05 #73281 by xandao
upload it to google drive and share it here, in reply, the link
09 Mar 2019 16:07 #73282 by xandao
I already tested all the firmware and none solved the problem, it does not connect even with the simulator .... copy the original will be the last hope .. !!
Time to create page: 0.117 seconds
