I8X-IR8M missing module A7105
- dheku
12 Mar 2019 10:57 #73312
by dheku
I8X-IR8M missing module A7105 was created by dheku
Hi.I use i8x-ir8m.
2 weeks ago, I updated firmware to deviation-ir8m-v5.0.0-2455ad1.
Problem has occurred so it indicated alert as missing modules A7105.
I confirmed hadrware.ini but it was not incorrect that enable A7105.
I want to fix this problem.
The problem was solved after changing firmware to deviation-ir8m-v5.0.0-b08efa8.
Is this bug?
Is this bug?
- Deezyy2476
18 Mar 2019 01:04 #73401
by Deezyy2476
Replied by Deezyy2476 on topic I8X-IR8M missing module A7105
Same here
- dheku
18 Mar 2019 14:19 #73412
by dheku
Replied by dheku on topic I8X-IR8M missing module A7105
Yes, your way is correct.
But I want to fix this problem in recently firmware.
Please tell me good idea or advice.
Thank you.
Thank you.
- Deezyy2476
18 Mar 2019 17:31 #73415
by Deezyy2476
I’m working on integrating the newest parameters
Into this firmware edition, from the newest. I’ll post here when complete.
- dheku
18 Mar 2019 22:23 #73419
by dheku
It's great!
- dheku
07 Apr 2019 16:58 #73723
by dheku
Hi.
I updated firm with deviation-ir8m-v5.0.0-32257c2.
But I couldn't bind E010 and E011c.
It dosen't fix A7i05 issue too.
The added scanner function is not useful because it is not displayed on the display.
I think the IR8M RF module is good
I hope for improvement.
Thank you for your actions and happiness will come.
Time to create page: 0.798 seconds
- I8X-IR8M missing module A7105
