- Bugs 3 mini "twitching" with jumper plus
- jbuck
21 Mar 2019 00:41 #73460
by jbuck
Bugs 3 mini "twitching" with jumper plus was created by jbuck
I have owned a jumper t8sg v2 plus for about a month now and am loving it. I updated the firmware (thanks to this site and the helpful community here) and it is working great. I have no issues with any models I fly with it except my recently purchased mjx bugs 3 mini.
It binds, flies, and I have all the channels programmed (arm, lights, flips, and acro/angle). When flying around the motors twitch a few times fast then smooth out. If it hovers it is smooth but while moving (any stick input), it is twitchy and the motors stutter a few times then fly smooth for a few seconds until they twitch again.
I have tried recharging the battery, rebinding, messing around with channels and trims, but it still acts the same.
When I use the stock transmitter to fly, it has no issues and flies smooth with zero twitches. I'll try to include a video of the flight to show the "twitching" when I can take a smaller size video I can upload here.
Has anyone else experienced this or something similar? Any suggestions to try? I have flown my regular bugs 3, xk x250, e011, and mantis85 all with no issues. Any help or suggestions would be greatly appreciated.
- C0ckpitvue 777
21 Mar 2019 01:31 #73462
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini "twitching" with jumper plus
I have the same problem when flying with my devos,it seems like it loses the connection at times even at short distances..
- jbuck
21 Mar 2019 09:36 #73467
by jbuck
Replied by jbuck on topic Bugs 3 mini "twitching" with jumper plus
Yeah it's weird it doesn't matter if it's 5 feet away from me or 100 feet it still acts the same. It never really loses control so much as the motors just seem to pulse on and off. I have had zero issues with range or anything with any other models flying on the jumper plus
- goebish
- NRF Weirdo
21 Mar 2019 10:01 - 21 Mar 2019 10:10 #73469
by goebish
Replied by goebish on topic Bugs 3 mini "twitching" with jumper plus
C0ckpitvue 777 is it only with recent builds or a problem you always had ?
This protocol should work properly, I fixed a bug recently (flips couldn't be disabled after being enabled ...) but nobody else has reported this issue so far.
Last edit: 21 Mar 2019 10:10 by goebish.
- C0ckpitvue 777
21 Mar 2019 19:43 #73476
by C0ckpitvue 777
The initial build there was a glitch also,I never said nothing because I just thought it was me.
- goebish
- NRF Weirdo
21 Mar 2019 19:46 #73477
by goebish
Can you check with a few different TX IDs ?
- C0ckpitvue 777
21 Mar 2019 20:31 #73479
by C0ckpitvue 777
Should I use the spreadsheet?I will try different Ids but they need to be provided,right now the weather is rainy but as soon as it clears up I will definitely try and report back.
- goebish
- NRF Weirdo
21 Mar 2019 20:32 #73480
by goebish
I mean Fixed ID, not the ID in protocol option, choose whatever you want, just try with a few different values (rebind required).
- jbuck
21 Mar 2019 20:34 #73481
by jbuck
I also noticed the flips cannot be disabled after binding, I need to turn tx and b3 mini off, switch off then turn on tx and b3 mini. I installed the latest build I found when I updated the firmware about a month ago
- goebish
- NRF Weirdo
21 Mar 2019 20:35 #73482
by goebish
That's normal, the fix for flip issue was merged a few days ago only.
- goebish
- NRF Weirdo
21 Mar 2019 20:36 #73483
by goebish
@jbuck, as it seems you easily reproduce the problem, can you try with a few different Fixed IDs as well ?
- jbuck
21 Mar 2019 20:40 #73484
by jbuck
I'm still fairly new to deviation, how would I change fixed ID's? I'll help any way I can
- goebish
- NRF Weirdo
21 Mar 2019 20:40 #73485
by goebish
Model menu -> Model setup -> Fixed ID
- jbuck
21 Mar 2019 20:41 #73486
by jbuck
I wonder if I should re-update since the flip issue was solved and see if it changes the twitches...
- jbuck
21 Mar 2019 20:45 #73487
by jbuck
My fixed ID is 123456
Do I erase and re-bind to change?
- goebish
- NRF Weirdo
21 Mar 2019 20:56 #73488
by goebish
Yes
- jbuck
21 Mar 2019 21:46 #73489
by jbuck
I deleted the fixed ID, randomly changed it, and re-bound 5 times. Every time the same issue is still there. Would it help to take a vid of the twitching and try to upload here? The vid I took already is way over the 2MB limit so I'd need to take another lower quality one
- goebish
- NRF Weirdo
21 Mar 2019 21:47 #73490
by goebish
just use youtube
- jbuck
21 Mar 2019 22:33 #73492
by jbuck
Here is a flight video that shows the twitching
- goebish
- NRF Weirdo
21 Mar 2019 22:47 #73493
by goebish
Ok, I'll try to understand what's wrong.
Time to create page: 1.787 seconds
