Bugs 3 mini "twitching" with jumper plus
21 Mar 2019 23:00 #73495 by jbuck
Replied by jbuck on topic Bugs 3 mini "twitching" with jumper plus
It's weird since I've seen other videos of the bugs 3 mini flying fine with the jumper plus... Maybe I'll try to update firmware again if that will help
21 Mar 2019 23:04 #73496 by goebish
Replied by goebish on topic Bugs 3 mini "twitching" with jumper plus
Yes, try with a recent nightly build please.
21 Mar 2019 23:11 #73497 by goebish
If you're still having the same issue with the latest build I'll make a test build without telemetry to check if that solves it.
21 Mar 2019 23:30 #73499 by JayDrone
Replied by JayDrone on topic Bugs 3 mini "twitching" with jumper plus
the issue i dont think is the build file - i would bank it is the users controller if they go into channel monitor i bet one or more channels is jumping and not stable - CALIBRATE UR CONTROLLER
22 Mar 2019 01:04 #73503 by jbuck
I did try monitoring channels in my tx but didn't see any jumping numbers. I also flew another drone (xk x250) right after and had no problems with that one. I calibrated the controller when I was setting it up but I can recalibrate to see if it helps.
22 Mar 2019 02:17 #73505 by jbuck
FIXED!
I updated with the latest nightly build and recalibrated the controller and everything works great now. Im not sure if it was the new firmware or the calibration but no more twitching. The flip mode now works and turns off too if I'd ever want to use it.
Thanks for all the quick responses and advice!
22 Mar 2019 08:42 #73508 by goebish
Nice!
I think it was the build, the firmware is under rework and we had a bug ~1 month ago, the SPI bus was running too slow.
22 Mar 2019 18:31 #73513 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini "twitching" with jumper plus
I also confirm the fix with the latest build,thanks again Goebish.
Time to create page: 0.504 seconds
