- Bugs 3 mini "twitching" with jumper plus
- jbuck
21 Mar 2019 23:00 #73495
by jbuck
Replied by jbuck on topic Bugs 3 mini "twitching" with jumper plus
It's weird since I've seen other videos of the bugs 3 mini flying fine with the jumper plus... Maybe I'll try to update firmware again if that will help
- goebish
- NRF Weirdo
21 Mar 2019 23:04 #73496
by goebish
Replied by goebish on topic Bugs 3 mini "twitching" with jumper plus
Yes, try with a recent nightly build please.
- goebish
- NRF Weirdo
21 Mar 2019 23:11 #73497
by goebish
If you're still having the same issue with the latest build I'll make a test build without telemetry to check if that solves it.
- JayDrone
21 Mar 2019 23:30 #73499
by JayDrone
Replied by JayDrone on topic Bugs 3 mini "twitching" with jumper plus
the issue i dont think is the build file - i would bank it is the users controller if they go into channel monitor i bet one or more channels is jumping and not stable - CALIBRATE UR CONTROLLER
- jbuck
22 Mar 2019 01:04 #73503
by jbuck
I did try monitoring channels in my tx but didn't see any jumping numbers. I also flew another drone (xk x250) right after and had no problems with that one. I calibrated the controller when I was setting it up but I can recalibrate to see if it helps.
- jbuck
22 Mar 2019 02:17 #73505
by jbuck
FIXED!
I updated with the latest nightly build and recalibrated the controller and everything works great now. Im not sure if it was the new firmware or the calibration but no more twitching. The flip mode now works and turns off too if I'd ever want to use it.
Thanks for all the quick responses and advice!
- goebish
- NRF Weirdo
22 Mar 2019 08:42 #73508
by goebish
Nice!
I think it was the build, the firmware is under rework and we had a bug ~1 month ago, the SPI bus was running too slow.
- C0ckpitvue 777
22 Mar 2019 18:31 #73513
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Bugs 3 mini "twitching" with jumper plus
I also confirm the fix with the latest build,thanks again Goebish.
Time to create page: 1.498 seconds
