v5.0.0 34c69eb PPM-in not working
21 Mar 2019 02:29 #73463 by masterpj555
v5.0.0 34c69eb PPM-in not working was created by masterpj555
Downloaded a nightly build purely because I wanted the fryskyX support to use my XM+ with my 4 in 1 module.
However I just installed my aomway commander v1 headtracking and activated it and sadly no response on any channel (or 7 or 8) on either the source channels or the PPM in channels... tried all PPM in modes.
Nothing happens in the interface visually... interface bugged or is it bricked?
When hooking it up to my pc's line in I hear the ppm changing when i turn the fpv goggles so clearly it's working.
21 Mar 2019 02:51 - 21 Mar 2019 04:07 #73464 by masterpj555
Replied by masterpj555 on topic v5.0.0 34c69eb PPM-in not working
I also noticed Aux4 and Aux 5 knob are not giving me any response.. not sending and not showing in the interface too.. something up with this build... recommended build for fryskyx?
*yes i did make sure the headers were plugged in properly.
Same problem with build 3.0.0 4.0.0... does the 4 in 1 cause problems??
It's so strange.. nothing is burned out.. i didnt do anything out of the ordinairy.. maybe someone knows troubleshooting steps?
Last edit: 21 Mar 2019 04:07 by masterpj555.
21 Mar 2019 04:20 #73466 by Gerry
Replied by Gerry on topic v5.0.0 34c69eb PPM-in not working
don't know about the PPM issue.
For Aux channels try calibrate tx including Aux knobs.
FFS (Forever Fixing Stuff)
21 Mar 2019 10:19 - 21 Mar 2019 10:29 #73471 by masterpj555
Aux working again thanks to your calibration advice! PPM-in not sure either but PPM-out does work!
Last edit: 21 Mar 2019 10:29 by masterpj555.
21 Mar 2019 14:10 #73472 by masterpj555
I looked at this thread.. set mode to extend and source ppm7 and ppm8.. restarted the devo 10.. powered on the fpv goggles first and magically its working now!
So strange as I did do this before and now its working.. Oh well!
Time to create page: 0.077 seconds
