- Wanted = Jumper T8SG + V2 build that is stable ..
- old4570
26 Apr 2019 00:55 #74137
by old4570
Wanted = Jumper T8SG + V2 build that is stable .. was created by old4570
Wanted = Stable Jumper T8SG + V2 build ..
Nightly builds keep crashing my Tx ...
Lost a build when re - installing windows ..
Anyone have a stable build ?
Thank you ..
Thank you ..
26 Apr 2019 03:23 - 26 Apr 2019 04:19 #74138
Replied by vlad_vy on topic Wanted = Jumper T8SG + V2 build that is stable ..
You can try custom build based on stable v.5.0.0 release. You will need full install, since filesystem is different. But, it hasn't new features: voice support, serial protocols ... If it doesn't help, you have hardware problem.
www.deviationtx.com/forum/builds/6407-de...cols?start=460#73210
Last edit: 26 Apr 2019 04:19 by vlad_vy.
- Moeder
26 Apr 2019 05:33 #74140
by Moeder
Replied by Moeder on topic Wanted = Jumper T8SG + V2 build that is stable ..
Can you please post the file error.txt found on the tx file system after the crash as well as the debug file that comes with the builds zip file here? This will help us look into the cause of the crashes.
- old4570
26 Apr 2019 09:50 #74142
by old4570
Replied by old4570 on topic Wanted = Jumper T8SG + V2 build that is stable ..
Error txt is empty ...
Everything reverts to as flashed after crash ...
I had a stable nightly build ! , ..... ( But I lost it )
- Moeder
26 Apr 2019 17:27 #74148
by Moeder
Can you give us more information on when those crashes happen? Any steps which reproducibly make the tx crash? Otherwise we can't look into this issue.
- old4570
27 Apr 2019 02:49 #74152
by old4570
It happens when ever !
I can be setting up a new model and it just turns off ..
It happens when I am trying to bind .
It happened once when I was just about to fly a micro quad ( Eachine E010 )
There is no one trigger ...
But I did have one nightly build where this did not happen . ( But I lost it ) ..
So ATM I just dont trust this Tx anymore ....
I sure would like to get my hands on a stable build , like the one that the transmitter is shipped with ..
Be nice to have something that can be trusted ( as much as possible )
An OS that turns off your Tx for no reason when it feels like it ? ( Thats NQR )
- Moeder
27 Apr 2019 18:53 #74154
by Moeder
Well, that nightlies can be unstable in some times is just something that can happen, and recently a lot of code work has been done in the background to lay grounds for future development. If you want to help fixing this issue, try to somehow narrow down the issue. For example does it even happen if you just have it turned on and not doing anything else, is there any specific time frame from boot up when this happens etc. There more precisely you can reproduce the issue, the easier it will be for developers to try to find the solution. The current information is of no help for anyone to even remotely narrow down the issue.
- old4570
28 Apr 2019 12:31 #74162
by old4570
Well , it's random ...
Unfortunately there are only so many nightly builds you can back track ...
Jumper is next to useless , but I might ask them to post the build they ship transmitters with ...
28 Apr 2019 14:53 #74164
16 May 2019 04:13 #74322
Probably it worth to create BRANCH_5.X from nightly builds Nov 8, 2018 commit, before massive changes, and integrate all new protocol changes. I think the best case was to release intermediate release before to do such massive changes.
Time to create page: 0.682 seconds
