Jumper t8sg plus v2 display fault
- Whik123
07 Jul 2019 22:56 #74706
by Whik123
Jumper t8sg plus v2 display fault was created by Whik123
all setup and ready to go flying switched on my t8sg v2 plus and got a scrambled screen worked fine last time i pick it up. anyway tried to work out the issue i updated to the latest firmware and still have the same screen fault anyone have any ideas i checked the ribbon cabble all seems fine. i think it might be a mainboard issue.
can i buy a replacement mainboard ???
08 Jul 2019 04:51 #74708
Replied by vlad_vy on topic Jumper t8sg plus v2 display fault
Try to use USB mode (Press ENT button and short press Power On). If you can see USB symbol, then format transmitter USB drive and copy filesystem from firmware archive.
- Whik123
08 Jul 2019 10:25 - 08 Jul 2019 10:43 #74711
I don't understand, can you see USB symbol on screen when you activate USB mode? If you see it, then LCD is OK.
For me, it looks like LCD memory damage. Will be better test this LCD with different T8SG V2 Plus.
Last edit: 08 Jul 2019 10:43 by vlad_vy.
- Whik123
08 Jul 2019 14:26 #74713
by Whik123
Replied by Whik123 on topic Jumper t8sg plus v2 display fault
08 Jul 2019 17:26 #74715
Something wrong with LCD.
- Whik123
10 Jul 2019 20:27 #74725
by Whik123
Smart guy thumbs up thank you it was just a broken track on the ribbon my repair attempt just made it worse
is there a replacement screen avalible anyware
Ps. T16 on its way
Attachment not found
Ps. T16 on its way
- Whik123
10 Jul 2019 20:33 #74726
by Whik123
Time to create page: 0.341 seconds
- Jumper t8sg plus v2 display fault
