4 in 1 module help.
- Dildor
22 Dec 2019 03:57 #75611
by Dildor
4 in 1 module help. was created by Dildor
I recently installed a 4 in 1 module on my devo 10 and installed deviation on the transmitter. It works on dsm2/x and devo models that i have, but i cannot get it to bind to my v911(flysky) or a800(KN). Im wondering if i botched the install, or if i am missing something in the model setup. On the install i'm certain i installed the leads to the correct locations. though i did overheat the pcb neer one of the locations on the main board for the devo 10. i'm guessing this could cause the other modules to not work properly, but kind of figured it would have fried the whole controller. any ideas on this?
- -=Hubi-Dirk=-
22 Dec 2019 11:18 - 22 Dec 2019 11:20 #75615
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic 4 in 1 module help.
Hi, you have surely removed the semicolons in the hardware.ini in the modules section and then saved the file?
At my Devo 12s it looks like this:
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
[modules]
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
Last edit: 22 Dec 2019 11:20 by -=Hubi-Dirk=-.
- Dildor
22 Dec 2019 22:55 #75618
by Dildor
Replied by Dildor on topic 4 in 1 module help.
I did as you said and removed the semicolons and received an error saying i was missing the 2401 module. I found that the port i had it wired to, from the diagram i copied, was labeled as b7. I changed this in the INI file and bingo! My plane is working! Thank you immensely for this pointer. I feel this is a huge step towards understanding how this system works .
- -=Hubi-Dirk=-
23 Dec 2019 02:47 #75620
by -=Hubi-Dirk=-
I'm very happy to hear that it was only due to the modification of the ini-file and there is no damage at your Devo.
Happy flying.
Happy flying.
Time to create page: 0.268 seconds
- 4 in 1 module help.
