- Jumper T8SG V2+ carbon: Voice selection + ...
- Rolf
- Devo 6s, Jumper T8SG v2+ carbon
12 Feb 2020 18:45 - 17 Feb 2020 18:13 #75910
by Rolf
Walkera Devo 6s, 7e and 10, Jumper T8SG v2+ lcd, Brain 2, Spektrum satellites and SPM4649T
Jumper T8SG V2+ carbon: Voice selection + ... was created by Rolf
I am running T8SQ_v2-v5.00-e90be75 from nightly builds in a jumper T8SQ V2 carbon with an lcd-screen.
I am using the German translation of Moeder voice_packs out the test builds in the sd-card.
So far it is running very nicely with screen and voice.
I noticed that
1. the German and the French voice_pack-translations have less entries than the English version of Moeder voice pack and
2. in the voice-config sub-menu of the model menu the maximum of the selectable voice-numbers is limited to 154 although there are far more voices stored on the sd-card and listed in the voice.ini-file in the media-folder.
I noticed that
Last edit: 17 Feb 2020 18:13 by Rolf.
- eried
14 Feb 2020 09:19 #75920
by eried
I have not checked that voice pack, but the official ones just use a text to speech service and they should not have less entries
If you are running an old firmware, there was a internal limitation (I was adding custom sounds too and I noticed this 154 limit), so upgrading to latest nightly should fix this part
github.com/DeviationTX/deviation/pull/950
Replied by eried on topic Jumper T8SG V2+ carbon: Voice selection + ...
Rolf wrote: I am running T8SQ_v2-v5.00-e90be75 from nightly builds in a jumper T8SQ V2 carbon with an lcd-screen.
Rolf wrote: 2. in the voice-config sub-menu of the model menu the maximum of the selectable voice-numbers is limited to 154 although there are far more voices stored on the sd-card and listed in the voice.ini-file in the media-folder.
- Rolf
06 Mar 2020 12:27 #76030
by Rolf
Replied by Rolf on topic Jumper T8SG V2+ carbon: Voice selection + ...
I tested the nightly built from 2020-03-06.
The limitation to 154 is still existent.
- eried
06 Mar 2020 12:47 #76032
by eried
Can you share your voice.ini ?
I am using actually up to the id 416 and it works ok. I have not tried more than that though.
- Rolf
06 Mar 2020 18:31 - 07 Mar 2020 15:49 #76034
by Rolf
I took Moeder's large German voice pack from the Downloads/Test Builds-section with its voice.ini and the corresponding mp3-files.
Comparing the voice-numbers (and titles) displayed on the voice-config-selection-panel with the voice-numbers in the voice.ini file, I understood after while, that the
voice-number on the voice-config-panel = voice number in ini-file - 200 +1
Therefore I got the impression that the number of selectable voices is limited to 154 (=353 - 200 +1). Sorry.
In my case the number of custom voices is not limited.
I noticed that only in the German and French mp3-files-section you can find filenames with identical starting numbers twice (e.g. 200) with otherwise differing filenames; in the English version the starting numbers of filenames are always different. I wondered what will happen in this case. It is only played one mp3-file.
Last edit: 07 Mar 2020 15:49 by Rolf.
Time to create page: 0.795 seconds
