Windows program to create 16 bit color pics ?
18 Sep 2012 13:41 #1722 by dado099
I would like to create bitmaps of my models (96x96 pixel 16 bit color, right?).
I got no problem to reduce pics at 96x96 pixel, but I can't find any program
to reduce color depth to 16 bit. Every program capable of color depth resizing only support 4, 8, 24 and 32 bit color depth.
What can I do to get 16 bit color depth ?
18 Sep 2012 14:04 - 18 Sep 2012 14:04 #1724 by rototophe
Replied by rototophe on topic Windows program to create 16 bit color pics ?
Try GIMP (free, available for windows/Linux) or Photoshop (not free, windows only).
Last edit: 18 Sep 2012 14:04 by rototophe.
18 Sep 2012 16:25 #1725 by magic_marty
Replied by magic_marty on topic Windows program to create 16 bit color pics ?
This is how Phracturedblue instructed me on how to convert photos using Gimp...
"Open the bmp by File->Open or draggig it into GIMP (I recommend setting Windows->Single Window Mode in order to make Gimp easier to use)
Then do File->Export To
Open 'Advanced' and set the type to either RGB565 or ARGB1555 depending on if you have transparency or not (both in the 16bit section)
Then save and you are done. "
it works perfectly i have assigned pics to all me models simple by making them 96x96 and using gimp to save them as above...
19 Sep 2012 08:42 #1740 by dado099
Replied by dado099 on topic Windows program to create 16 bit color pics ?
Thank you marty,
very helpful !
19 Sep 2012 12:56 #1743 by PhracturedBlue
Replied by PhracturedBlue on topic Windows program to create 16 bit color pics ?
FYI, I created a new section for folks to share their model icons. Please only upload images that you have the right to share.
19 Sep 2012 13:11 #1746 by FDR
Do we need a separate forum just for the model bitmaps?
If a model config references one, I think it is best to attach the bitmap with it in the same post...
Time to create page: 0.099 seconds
