Full servo travel over half of the rudder stick?
15 Nov 2020 04:33 #77012 by Staron
Is there a way to get set up my rudder stick to make a servo travel the full range while just moving the stick half way?
15 Nov 2020 14:48 #77013 by propnut
Create a curve and then assign that to the channel
16 Nov 2020 05:08 #77017 by Staron
I'm sorry but I don't know what that means. Is that done in the mixer for the rudder channel?
16 Nov 2020 09:05 - 16 Nov 2020 09:06 #77018 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Full servo travel over half of the rudder stick?
Try it with a 5-point curve the way you need it. The values in the example are:
Point 1: -100
Point 2: -100
Point 3: 0
Point 4: 100
Point 5: 100
Attached are two pictures for overview.
Last edit: 16 Nov 2020 09:06 by -=Hubi-Dirk=-.
16 Nov 2020 19:17 #77021 by Staron
Thank you, that helped . I guess my issue is getting my servo to move the full 180 deg. verses only 90 deg.
16 Nov 2020 23:17 #77022 by propnut
What in either direction of the stick or only in one direction ?
17 Nov 2020 00:35 #77023 by Staron
The servo only moves 45 deg each way.
17 Nov 2020 07:12 #77025 by -=Hubi-Dirk=-
Is the servo specified for 180° movement?
Btw: It would be nice to get some more information about what you have in mind. Describe the application with your words to make it clearer and easier to understand.
Time to create page: 0.208 seconds
