Does Deviation has potential to get CloneTX funct?
12 Mar 2021 01:52 - 12 Mar 2021 01:55 #77310 by BlackLotus
Very thanks for easy and powerful firmware.
I hope to using Cloning frsky TX function, like other 4in1 multi-module.
Or it's already done here, but I can't find?
Newbie who using Devo 10
Last edit: 12 Mar 2021 01:55 by BlackLotus.
12 Mar 2021 04:31 - 12 Mar 2021 04:33 #77311 by vlad_vy
You can't clone current transmitter ID, but you can use the same ID with different Deviation Tx. You will need rebind all receivers with any transmitter.
In the top-section of hardware.ini (above [modules]), set some random 8-character hex value:
txid = xxxxxxxx
(each x can be 0-9,a-f)
Generator:
rumkin.com/tools/password/pass_gen.php
Last edit: 12 Mar 2021 04:33 by vlad_vy.
12 Mar 2021 04:45 #77312 by BlackLotus
Oh, very thanks vlad_vy for quick reply. :)
But I can't understand needs of matching Transmitter ID to another if it still needs to rebind.
Sorry for question again.
12 Mar 2021 07:18 #77313 by vlad_vy
If you change TXID to custom, you need rebind model once. You don't need bind model to second transmitter with the same TXID.
12 Mar 2021 08:23 #77314 by BlackLotus
Thanks for perfect explanation!
Very happy to knowing that :)
13 Mar 2021 21:09 #77315 by Fernandez
And how to read the TxID from your radio, if you have not entered your own Custom TxID in hardware.ini inside your excisting radio? Can we make it visible ?
Time to create page: 0.202 seconds
