Update firmware jumper T 8 SG V2
01 May 2022 06:08 #77958 by Psychonauth
Update firmware jumper T 8 SG V2 was created by Psychonauth
I can't get the frysky R-XSR reciver bind with my jumper T8 SG plus V2 transmitter. I am still made a firmware update, i am running t8sg_v5.0.0-abc5dcf, without solvi g the problem. Witch version is the right ones?
01 May 2022 13:39 #77959 by machead
Replied by machead on topic Update firmware jumper T 8 SG V2
Is your receiver with ACCST or ACCESS f/w? I believe it can be bound in ACCST D16 mode only.
01 May 2022 19:49 #77961 by Psychonauth
Replied by Psychonauth on topic Update firmware jumper T 8 SG V2
It is ACCST. Yes, you are right. It did't bind...
02 May 2022 02:52 #77962 by hexfet
Replied by hexfet on topic Update firmware jumper T 8 SG V2
There's two versions of ACCST these days. If your XSR is ACCST v1 it should work with the firmware you have. Try the fine freq adjustment to see if you can bind. If the XSR is ACCST v2 then install the firmware from here . This build has another protocol option for FrskyX to set the ACCST version.
04 May 2022 05:17 #77963 by Psychonauth
Thank you Hexfet.
12 May 2022 20:02 #77982 by Psychonauth
Thank you very much Hexfet!
13 May 2022 01:41 #77984 by hexfet
You're welcome
Time to create page: 0.098 seconds
