Missing Modules: MultiMod after upgrade
- phantom8
09 Jun 2023 03:00 - 09 Jun 2023 03:51 #78278
by phantom8
Missing Modules: MultiMod after upgrade was created by phantom8
Just returned to the hobby after a few years break. Upgraded my Ultimate 7e to the latest build from Hexfet "deviation-devo7e-256-v5.0.0-408f8c0". Got the error message "Missing Modules: MultiMod" right after upgrade. Has the hardware.ini file format changed? I'm using the original multimodule by PB. Appreciate for any suggestions. Here is the modules section of hardware.ini file I'm using:
[EDIT]
Installed the official nightly build on 2021-06-06 "deviation-devo7e-256-v5.0.0-c84450e", same problem. Tried the official release "deviation-devo7e-v5.0.0" and it works fine.
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 0
enable-a7105 = S1
has_pa-a7105 = 1
enable-cc2500 = S3
has_pa-cc2500 = 1
enable-nrf24l01 = S402
has_pa-nrf24l01 = 1
enable-multimod = A13[EDIT]
Last edit: 09 Jun 2023 03:51 by phantom8.
- phantom8
11 Jun 2023 13:00 - 11 Jun 2023 13:03 #78280
by phantom8
Replied by phantom8 on topic Missing Modules: MultiMod after upgrade
The problem is caused by JTAG not completely disabled which was originated in early 2019 during major code restructure. It's quite strange nobody reported this problem for so many years. Maybe most have moved onto other transmitters. Anyway, I've created a pull request for the fix.
Last edit: 11 Jun 2023 13:03 by phantom8.
Time to create page: 0.086 seconds
- Missing Modules: MultiMod after upgrade
