Radiomaster TX 15 Module for devo receivers ?
29 Mar 2026 11:39 - 29 Mar 2026 12:55 #78851 by Krum
Hey guys i recently ordered a radiomaster tx 15 and i have quite a lot devo receivers on my models.
Is there a module i can buy so i can still use my old receivers
and if so what settings do i need to do in EdgeTx to make it work.
I am looking into the Radiomaster 2.4GHz RM 4IN1 module or the JUMPER 2.4GHz JP4IN1 Multi-Protocol but i am not sure if they support the devo receivers.
also not sure if the jumper module will work with the radiomaster radio and i think i will need a adapter from nano to micro for it,
i would prefer the module to be more powerful so the jumper one is at 150mw and the radiomaster is at 100mw
hope there are people still alive in this forum, i been rocking my old devo 10 since 2013 so maybe its time to upgrade. :side:
Last edit: 29 Mar 2026 12:55 by Krum.
29 Mar 2026 14:00 #78852 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Radiomaster TX 15 Module for devo receivers ?
The TX 15 has a JR module bay; for this, there are 4-in-1 multi-protocol modules from Radiomaster or the IRX4 module from iRangeX.
EdgeTX: In the model settings, select “External RF,” then set the mode to "ON" then “MULTI,” select the “Devo” protocol, and then bind with the RX.
Time to create page: 0.078 seconds
