devo10 displays incorrect characters
- suvsuv
03 Oct 2012 15:00 - 04 Oct 2012 14:29 #1952
by suvsuv
devo10 displays incorrect characters was created by suvsuv
Hi PB, I download a test version of deviation10 with my own codes into my devo10. By copying the whole filesystem to the devo10 afterward, it does show words as I expect.
However, after I flash walkera's dfu and lib (DEVO-10 Fw v0.6A.dfu, DEVO-10 Lib v0.2.dfu) back to the devo10, it just displays unrecognized font/character though it still works as before.
Do you know how do I restore the devo10 with correct font/characters?
Last edit: 04 Oct 2012 14:29 by FDR.
- suvsuv
03 Oct 2012 15:03 #1954
by suvsuv
Replied by suvsuv on topic devo10 displays incorrect characters
Here is the picture of the test version
It is a good start. But I just want to have the option to flash back Walkera's firmware before a workable deviation version of devo10 is released.
Thanks in advance
Thanks in advance
03 Oct 2012 15:05 #1955
Replied by FDR on topic devo10 displays incorrect characters
You have probably "upload"-ed the library, instead of "upgrade"-ing it, so you overwrote the orig lib file with the contents of the flash.
Download the original library again from the Walkera site, and do care about to select it into the "Upgrade or Verify File" section and push the "Upgrade" button...
- suvsuv
03 Oct 2012 16:31 #1958
by suvsuv
Thanks FDR, everything is fine with my devo 10 now
04 Oct 2012 01:13 #1965
Replied by PhracturedBlue on topic devo10 displays incorrect characters
Also, note that the deviation10 branch was just for testing.
the current code code in the main codebase ('deviation') has the most recent deviation code. It won't actually work as-is because the 'main()' function hasn't been updated, but it includes the new directory structure and the latest drivers.
- richardclli
04 Oct 2012 01:47 #1969
by richardclli
Replied by richardclli on topic devo10 displays incorrect characters
Hey, suvsuv, you here as well
- suvsuv
04 Oct 2012 14:38 - 04 Oct 2012 14:39 #1982
by suvsuv
Hi Richardli, I saw your check-in Chinese font into the deviation trunk for devo 8 already, good for 5imx's devo users
Hopefully, we can have a devo10 release as most Chinese users own devo10 more than devo8
Last edit: 04 Oct 2012 14:39 by suvsuv.
- richardclli
04 Oct 2012 14:55 #1985
by richardclli
Yes, I myself owns a Devo 10 as well, but I rather prefer an English interface, ha ha
Time to create page: 0.274 seconds
- devo10 displays incorrect characters
