- Devo10 device doesn't respond to key press(Fixed)
- suvsuv
06 Oct 2012 01:37 - 07 Oct 2012 03:27 #2009
by suvsuv
Devo10 device doesn't respond to key press(Fixed) was created by suvsuv
I coded the main page for devo10, it works fine with emulator. However, after I had codes flashed to real devo10 devices, it doesn't respond to key press, e.g. the timer1 should start /stop when UP is pressed and should reset when Ext is pressed. In addition, the throttle value is not updated in the main page screen.
PB, could you please check out codes from the deviationfor6810 repo and help me figure out what is wrong with my codes?
BTW, there is a minor bug in devo10's tx_buttons.c , Line 46-47 should be as follows, PB, please let have it fixed in your main repo
gpio_set_mode(GPIOB, GPIO_MODE_OUTPUT_50_MHZ,
GPIO_CNF_OUTPUT_PUSHPULL, GPIO4 | GPIO5 | GPIO8 | GPIO9);
Last edit: 07 Oct 2012 03:27 by suvsuv.
- suvsuv
06 Oct 2012 01:47 - 06 Oct 2012 01:50 #2010
by suvsuv
Replied by suvsuv on topic Real devo10 device doesn't respond to key press
Last edit: 06 Oct 2012 01:50 by suvsuv.
- suvsuv
06 Oct 2012 08:06 #2015
by suvsuv
After more test, I found only the buttons connected to PORTB.GPIO4(UP,DN and Ext) don't work, all other buttons work properly.
So I tried change codes related to B.4, I got no good result yet. Any idea from PB and xC?
And I have a question about why the B.5 pin should be set to 0 instead of setting to 1 as B.4/8/9
/* PB.4 = 1, PB.5 = 0, PB.8 = 1, PB.9 = 1 */
gpio_set(GPIOB, GPIO4 | GPIO8 | GPIO9);
gpio_clear(GPIOB, GPIO5);
- suvsuv
07 Oct 2012 03:18 #2019
by suvsuv
Finally got the issue solved, it is caused by conflicting with the SPI touch which uses the PB.5 pin as well. So the main() function should conditionally comment out functions related to SPI touch for devo10
void Init() {
CYRF_Initialize();
#ifdef PROTO_HAS_A7105
A7105_Initialize();
#endif
#if !defined(devo10) && !defined(emu_devo10)
SPITouch_Init(); // Comment out as conflicted with devo10's PB.5 connection(UP/DN/Ext key)
#endif
SOUND_Init();
void EventLoop()
if (CLOCK_getms() > next_scan) {
MIXER_CalcChannels();
BUTTON_Handler();
TOUCH_Handler(); // Comment out as conflicted with devo10's PB.5 connection(UP/DN/Ext key)
#endif
PAGE_Event();
void Init() {
CYRF_Initialize();
A7105_Initialize();
#endif
#endif
SOUND_Init();
void EventLoop()
BUTTON_Handler();
#endif
PAGE_Event();
- suvsuv
07 Oct 2012 03:23 - 07 Oct 2012 03:31 #2020
by suvsuv
Hi PB, please also modify the tx_button.c under the devo10 foloder to fix minor bug with GPIOB pins' assignment
Last edit: 07 Oct 2012 03:31 by suvsuv.
- thloh85
07 Oct 2012 10:08 #2023
by thloh85
Replied by thloh85 on topic Devo10 device doesn't respond to key press(Fixed)
Looks like u've made a lot of progress for Devo10. Thanks for the hard work...
Time to create page: 0.381 seconds
