- How to enable throttle hold in current devo8 build
- suvsuv
11 Oct 2012 02:34 #2150
by suvsuv
How to enable throttle hold in current devo8 build was created by suvsuv
I don't see the throttle hold setting in current devo8's GUI, and I found the following pins that might be related to thro hold. So I want to know how to set these pins
CYRF_WriteRegister(CYRF_11_DATA32_THOLD, 0x05);
CYRF_WriteRegister(CYRF_12_DATA64_THOLD, 0x0E);
- magic_marty
11 Oct 2012 03:25 #2151
by magic_marty
Replied by magic_marty on topic How to enable throttle hold in current devo8 build
? i use throttle hold on mine are you sure its not there? i had to remap it to a different switch but its there...
11 Oct 2012 04:35 #2152
Replied by FDR on topic How to enable throttle hold in current devo8 build
Isn't that transmittion hold?
There is no dedicated throttle hold functionality in deviation as there is no dedicated throttle channel either.
I used to use the channel's safety feature for it, or alternatively you can use a plus complex mixer page too...
- suvsuv
11 Oct 2012 04:51 #2153
by suvsuv
Replied by suvsuv on topic How to enable throttle hold in current devo8 build
Thanks FDR. So I need to figure out a way to control and monitor throttle channel if I want to provide direct setting for Thro Hold feature. Do you and PB has any suggestion about it
11 Oct 2012 05:17 - 11 Oct 2012 05:21 #2154
Replied by vlad_vy on topic How to enable throttle hold in current devo8 build
Complex mixer - example at last page of User's Manual (page 21), page 4 of complex mixer, for 'Throttle Hold' used 'GEAR' switch.
Channel configuration - (page 14), Safety: [switch], Value: -100%.
Last edit: 11 Oct 2012 05:21 by vlad_vy.
- flint723
11 Oct 2012 05:50 #2155
by flint723
Replied by flint723 on topic How to enable throttle hold in current devo8 build
11 Oct 2012 07:44 #2156
If you want to implement your own traditional interface, which should have a fixed throttle hold feature, you have to determine first from the protocol, which channel is the throttle.
Then the question is, do you wish to use the current mixer functions in the background, or will you reimplement the whole operation from stratch. In first case the aforementioned safety feature is your best bet...
However in that case you should support some multi engine scenarios as well, and implement your throttle hold to take it into account...
In deviation any channel can be throttle, you can cut them all if you wish...
suvsuv wrote: Thanks FDR. So I need to figure out a way to control and monitor throttle channel if I want to provide direct setting for Thro Hold feature. Do you and PB has any suggestion about it
- suvsuv
11 Oct 2012 08:36 #2157
by suvsuv
Thanks vlad_vy and FDR, now I understand how throttle hold works
Time to create page: 0.305 seconds
