DSM2 Reports
01 Dec 2012 19:03 #3507 by coaster
Replied by coaster on topic DSM2 Reports
thanks for the solution, now my sunday work is to adjust all
my DSM2 models !
cheers
Graziano
01 Dec 2012 20:25 #3508 by Hexperience
Replied by Hexperience on topic DSM2 Reports
Good point.
PB, maybe that should be added to the release notes and/or in the announcement page.
Cheers
03 Dec 2012 14:32 #3565 by PhracturedBlue
Replied by PhracturedBlue on topic DSM2 Reports
Done
17 Dec 2012 17:19 #4062 by clearprop88
Replied by clearprop88 on topic DSM2 Reports
I'm trying to setup my new AR7200BX on my Devo 6 with Deviation FW version v1.1.1
I have the Heli 6 chan template loaded, and am using DSM2 TX protocol.
THR appears on ch 1
AIL on ch2
ELE on ch 3
This is unusual because all other protocols use THR on CH3.
Anyway I can't get it to work properly.
Has anyone setup a BX on Deviation?
My experience so far is that I have successfuly setup a 2702V, and RX2618V using the 6 ch template on my Devo 6.
I think the Heli 6 ch template doesn't apply to DSM2 rx's.
I moved the THR, complex functions to CH 1, and changed CH 3 to ELE, simple.
But this throws the template labels off.
I haven't tried it yet but I think this might work.
17 Dec 2012 17:44 - 17 Dec 2012 17:50 #4063 by PhracturedBlue
1st, DSM2 support in 2.1 is much more reliable than with 1.1.1.
2nd, you are right that the 6ch heli template doesn't work properly with DSM2. That is a bug limitiation in how templates work. In 2.1, you can reorder the channels after applying the template as a work-around. For 1.1.1 there isn't much you can do other than changing servo positions or building the configuration from scratch.
I'll take a look at the template and see if there is anything I can do to make it work properly with DSM2.
Last edit: 17 Dec 2012 17:50 by PhracturedBlue.
17 Dec 2012 17:58 #4065 by clearprop88
I'll load in 2.1, and go from there.
Thanks for your help.
18 Dec 2012 18:16 #4095 by clearprop88
More on my 7200BX setup.
I have the swash working, and it moves as it should.
I'm using the following settings on the tail.
4-RUD Simple, SRC RUD, Curve 1-to-1, Scale 80
5-GEAR Simple, SRC GEAR, Curve 1-to-1, Scale 40
The tail seems to be responding OK, on the bench, but I'm not sure it's the best setup.
This is my first attempt at a DSM setup, so any help would be appreciated.
Time to create page: 0.095 seconds
