DSM2 Reports
25 Oct 2012 05:30 #2412 by magic_marty
Replied by magic_marty on topic DSM2 Reports
i have the 1.1.2 deviation installed shouldn't it have the safety in it?
25 Oct 2012 05:33 #2413 by magic_marty
here is what the model file looks like...
name=Model7
type=plane
[radio]
protocol=DSM2
num_channels=6
fixed_id=654321
tx_power=100mW
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
template=expo_dr
[mixer]
src=AIL
dest=Ch2
[mixer]
src=AIL
dest=Ch2
switch=AIL DR
scalar=60
[channel3]
template=expo_dr
[mixer]
src=ELE
dest=Ch3
[mixer]
src=ELE
dest=Ch3
switch=ELE DR
scalar=60
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
switch=RUD DR
scalar=60
[channel5]
template=expo_dr
[mixer]
src=GEAR
dest=Ch5
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Ch3=min
[gui-qvga]
trim=4in
barsize=half
box1=Ch3
box2=timer1
box3=timer2
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=1
toggle2=AIL DR
toggle3=RUD DR
tglico3=2
toggle4=GEAR
tglico4=4
25 Oct 2012 05:43 #2414 by magic_marty
coaster wrote: look at the [trim1] Section and insert/replace
this: [safety]
Auto=min
cheers
Graziano
tried it and it didn't work it still says "Ch3 is 0%, safe value = -100%
25 Oct 2012 05:52 #2415 by vlad_vy
Replied by vlad_vy on topic DSM2 Reports
magic_marty wrote: here is what the model file looks like...
name=Model7
type=plane
[radio]
protocol=DSM2
num_channels=6
fixed_id=654321
tx_power=100mW
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
template=expo_dr
[mixer]
src=AIL
dest=Ch2
[mixer]
src=AIL
dest=Ch2
switch=AIL DR
scalar=60
[channel3]
template=expo_dr
[mixer]
src=ELE
dest=Ch3
[mixer]
src=ELE
dest=Ch3
switch=ELE DR
scalar=60
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
switch=RUD DR
scalar=60
[channel5]
template=expo_dr
[mixer]
src=GEAR
dest=Ch5
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Ch3=min
- replace with Auto=min
[gui-qvga]
trim=4in
barsize=half
box1=Ch3
box2=timer1
box3=timer2
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=1
toggle2=AIL DR
toggle3=RUD DR
tglico3=2
toggle4=GEAR
tglico4=4
25 Oct 2012 05:54 #2416 by FDR
Replied by FDR on topic DSM2 Reports
There IS a safety section in there.
Replace "Ch3=min" with "Auto=min"
name=Model7
type=plane
[radio]
protocol=DSM2
num_channels=6
fixed_id=654321
tx_power=100mW
[channel1]
template=simple
[mixer]
src=THR
dest=Ch1
[channel2]
template=expo_dr
[mixer]
src=AIL
dest=Ch2
[mixer]
src=AIL
dest=Ch2
switch=AIL DR
scalar=60
[channel3]
template=expo_dr
[mixer]
src=ELE
dest=Ch3
[mixer]
src=ELE
dest=Ch3
switch=ELE DR
scalar=60
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
switch=RUD DR
scalar=60
[channel5]
template=expo_dr
[mixer]
src=GEAR
dest=Ch5
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Ch3=min
[gui-qvga]
trim=4in
barsize=half
box1=Ch3
box2=timer1
box3=timer2
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=1
toggle2=AIL DR
toggle3=RUD DR
tglico3=2
toggle4=GEAR
tglico4=4
25 Oct 2012 06:09 #2417 by magic_marty
i got it...took a while to do all the model files but it works now...thanks all..:)
27 Oct 2012 22:38 #2447 by PhracturedBlue
Replied by PhracturedBlue on topic DSM2 Reports
Here is a new release that should fix the brownout issue and support > 7 channels. It is only very lightly tested due to my lack of DSM2 hardware at the moment.
www.deviationtx.com/forum/5-news-announc...-dsm2-telemetry#2445
28 Oct 2012 07:38 - 28 Oct 2012 10:51 #2451 by vlad_vy
After testing (with Spektrum AR6210, JR RD921):
1) Binding and brownout detection working normally.
2) Any channel not working at all.
3) Reboot for exit from USB page (russian interface) solved.
4) Telemetry info now updated at main page.
5) Font for Telemetry page (Volt1,2,3, Temp1,2,3,4, RPM1,2) will be better make black. White color difficult to see.
6) Mixer page (with Russian interface): if displayed small font (assigned switches), I can see numbers only. Next channel also display buttons with small font (I cann't see this font with russian interface). If channel have not assigned switches, next channel will display buttons with normal font.
Example:
[1-THR] THR [Expo&DR] FMODE1 FMODE2
[2-AIL] AIL [Expo&DR] MIX1 MIX2
[3-ELE] ELE [Expo&DR] MIX1 MIX2
[4-RUD] RUD [Simple]
[5-GEAR] GEAR [Simple]
With Russian interface:
[1-THR] THR [Expo&DR] 1 2
[2- ] AIL [ & ] 1 2
[3- ] ELE [ & ] 1 2
[4- ] RUD [ ]
With test build b5b5461b2ff7 I havn't problem with small font for buttons, only with small font for assigned switches.
Last edit: 28 Oct 2012 10:51 by vlad_vy.
28 Oct 2012 14:55 - 28 Oct 2012 14:56 #2453 by PhracturedBlue
I've updated build so that DSM2 channels work. Try to grab the new version.
It isn't surprising that you can't see the small-font. It does not contain the cyrillic characters. I'll need to think about how to handle that.
The telemetry stuff is not yet complete.
Last edit: 28 Oct 2012 14:56 by PhracturedBlue.
28 Oct 2012 16:39 - 28 Oct 2012 16:56 #2454 by vlad_vy
I understand issue with small font and russian language, but why small font appears on buttons?
I've tested new build (fc31fd71caa8), only 4-RUD channel working properly, others 1-7 channels working incorrectly - vibrate, respond after long delays and so on, 8-9 channels don't working.
Last edit: 28 Oct 2012 16:56 by vlad_vy.
28 Oct 2012 17:43 - 28 Oct 2012 18:03 #2455 by PhracturedBlue
I'm not clear on what you mean.
Did you test #channels =6, 7, 8, 9?(make sure to rebind each time)
is it the same in all cases?
what Rx are you testing with? Sorry, my reading comprehension isn't very good.
I've had reports that it is at least basically functional. Until I have replacement DSM2 hardware, I'm quite limited in what I can test myself.
Edit: I've fixed the issue with the fonts on buttons. It'll be in the next release
Last edit: 28 Oct 2012 18:03 by PhracturedBlue.
29 Oct 2012 13:58 #2466 by vlad_vy
Spektrum AR6210
At 6 and 7 channels mode, all working fine. At 8 and 9 channels mode, any channel not working at all.
JR RD921
At 6 and 7 channels mode, all working fine. At 8 channel mode, 1-7 channels working incorrectly - interrupted movement, 8 channel don't working. At 9 channel mode only 4-RUD channel working properly, others 1-7 channels working incorrectly - vibrate, respond after long delays and so on, 8-9 channels don't working.
29 Oct 2012 15:40 - 29 Oct 2012 15:41 #2467 by vlad_vy
I see at DSM.txt:
A packet consists of a Tx ID + upto 7 channels of data
each 16bit data value is defined as:
10bit:
a 0 bbbb cccccccccc
11bit:
a bbbb ccccccccccc
a: 0 for 1st data packet, 1 for 2nd data packet
bbbb: the channel number of this packet
cc..: 10 or 11bit channel data (MSB 1st)
At other source I see:
Data from a tranmitter with 10 bit resolution has the form:
[F 0 C3 C2 C1 C0 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0]
Data from a tranmitter with 11 bit resolution has the form
[F C3 C2 C1 C0 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0]
where :
0 means a '0' bit
F: Normally 0 but set to 1 for the first channel of the 2nd frame if a second frame is transmitted.
C3 to C0 is the channel number, 4 bit, matching the numbers allocated in the transmitter.
D9 to D0 is the channel data (10 bit) 0xaa..0x200..0x356 for 100% transmitter-travel
D10 to D0 is the channel data (11 bit) 0x154..0x400..0x6AC for 100% transmitter-travel
Last edit: 29 Oct 2012 15:41 by vlad_vy.
29 Oct 2012 18:15 #2471 by PhracturedBlue
Good catch. The docs you mention are correct. I improperly documented DSM.txt (and then subsequently implemented it incorrectly). This likely explains the 8/9 ch issue.
For some reason 11bit mode also didn't work reliably, so at the moment, I'm only using 10-bit mode. I probably won't dig into that until my DSM2/X hardware arrives.
30 Oct 2012 01:20 #2479 by PhracturedBlue
I've updated the dfu and filesystem again at the above link:
www.deviationtx.com/forum/5-news-announc...2-telemetry-update-2
Make sure to grab both the fs and the dfu, and update the config.ini file (in the media dir)
This release is my attempt to work with >7 channels. Of course, I can't actually test it myself.
30 Oct 2012 11:20 #2490 by vlad_vy
I cann't find in DSM.txt what data used at unused channels.
"14 bytes - up to 7 channels (16 bit word per channel) with encoded channel number, channel value, the "2nd frame in a sequence" flag. Unused channels have FF FF instead of data bytes."
30 Oct 2012 12:32 #2491 by PhracturedBlue
true, I didn't document it, but that is already coded in the protocol. I'll make sure I add it to the documentation
30 Oct 2012 13:51 - 30 Oct 2012 13:55 #2496 by vlad_vy
Test with 87729ce290cb build
Spektrum AR6210
At 6 and 7 channels mode, all working fine. At 8 and 9 channels mode, 1-6 channels working incorrectly - vibrate, interrupted movement, respond after long delays and so on. But now, at 8 and 9 channel mode, Rx respond.
JR RD921
At 6 and 7 channels mode, all working fine. At 8 channel mode, 1-7 channels working incorrectly - interrupted movement, 8 channel don't working. At 9 channel mode only 4-RUD channel working properly, others 1-7 channels working incorrectly - vibrate, respond after long delays and so on, 8 channel don't working, but 9 channel now working with interrupted movement.
Last edit: 30 Oct 2012 13:55 by vlad_vy.
30 Oct 2012 16:06 #2504 by Wene001
Replied by Wene001 on topic DSM2 Reports
The same here for me with an Orange 9CH Rx
31 Oct 2012 16:39 #2545 by vlad_vy
It's not related to DSM2, but I found at dsm2.c - build_bind_packet()
#if DSMX
packet[12] = num_channels < 8 ? 0xa2 : 0xb3; ??? 0xb2 ???
Time to create page: 0.087 seconds
