Binding problem Master CP
- Muskoka
30 Nov 2012 19:02 #3461
by Muskoka
Binding problem Master CP was created by Muskoka
Can't seem to get my Master CP bound without having the receiver flashing after it binds. Cleared the fixed id ok (I think), can get it bound, but receiver continues to flash.
Glen
Glen
30 Nov 2012 19:41 #3466
Replied by FDR on topic Binding problem Master CP
Do the servos move?
May be you didn't configured the gyro channel, and that's why it is flashing...
- Muskoka
30 Nov 2012 19:55 - 30 Nov 2012 19:55 #3467
by Muskoka
Replied by Muskoka on topic Binding problem Master CP
Yup servos move. I thought that put cant for the life of me figure out how to even set the gyro. I have no problem with my Dx6i, Dx8 or the stock Devo 10 software, but finding my way around Deviation has been tough to say the least. Any shove in the right direction would help. I have read and reread the manual, still having a tough time.
Last edit: 30 Nov 2012 19:55 by Muskoka.
30 Nov 2012 20:05 #3468
On the Ch7 setup a simple mixer like that:
src=anything but none
curve=fixed
scale=the gyro value, let's say 90%
offset=0 (default)
curve=fixed
offset=0 (default)
- Muskoka
30 Nov 2012 20:10 #3469
by Muskoka
Ok, that worked, thank you, no more flashing receiver. Now, I have no collective / throttle movement, cyclic is fine.
30 Nov 2012 20:36 #3470
Ch3 (throttle)
make it an Expo&DR mixer:
src=THR
switch1=FMODE1
switch2=FMODE2
High-Rate funtion=1-to-1
(click on Mid-Rate and Low-Rate to unlink their function)
Mid-Rate function=3 point
with values: 100, 80, 100
Low-Rate function=3 point
with values: 100, 100, 100
Ch6 (pitch)
Simple mixer:
src=THR
curve=1-to-1
scale=about 60-70%
offset=0
If you want different pitch curves for the flight modes, you can setup it like the throttle channel, but with different 3 point curve values...
src=THR
switch1=FMODE1
switch2=FMODE2
Ch6 (pitch)
Simple mixer:
src=THR
curve=1-to-1
scale=about 60-70%
offset=0
- Muskoka
30 Nov 2012 20:42 #3471
by Muskoka
Thanks, I'll work through it. I found your template files, but I can't seem to find "Template" in my Devo 10 under Model. I've looked elsewhere and can't find template.
30 Nov 2012 20:45 #3472
Templates can be loaded from the model setup page file box: change it to "Template..." and click on it...
- Muskoka
30 Nov 2012 21:02 - 30 Nov 2012 21:03 #3473
by Muskoka
Got it....thank you. Pitch curves set up fine. Still can't find where to load a template, do you just do that under "File"...."Load"?
Edit. ok found where to load templates.
Thanks for the help, on my way.
Last edit: 30 Nov 2012 21:03 by Muskoka.
- Muskoka
30 Nov 2012 21:20 #3475
by Muskoka
Ha ha, just figured out how to set the throttle hold, proud of myself.
Time to create page: 0.602 seconds
- Binding problem Master CP
