Walkera +deviation firmware+which simulator?
20 Oct 2013 12:34 #14801 by EduardS
Replied by EduardS on topic Walkera +deviation firmware+which simulator?
Is it possible that Deviation 8S latest nightly build doesn't give any PPM output? With Deviation 10 3.0 I don't have any problem with my simulator.
  • rbe2012
  • rbe2012's Avatar
20 Oct 2013 15:08 #14809 by rbe2012
Replied by rbe2012 on topic Walkera +deviation firmware+which simulator?
No,
I just tested with my Devo8s and encountered no problem. There is no general issue (i use ClearView).
20 Oct 2013 19:34 - 20 Oct 2013 19:35 #14816 by EduardS
That is weird. With Devo 10 with Deviation 3.0 I have no problem with my simulator (Phoenix), but with Devo 8S on latest nightly build, Pnoenix recognizes the transmitter but there is no channel activity on all channels.
Last edit: 20 Oct 2013 19:35 by EduardS.
20 Oct 2013 20:31 #14817 by FDR
Did you compile that?
The development compilation uses the trainer port for debug messages, so there is no PPM out if you compile that way...
  • rbe2012
  • rbe2012's Avatar
21 Oct 2013 06:27 #14823 by rbe2012
If you have compiled with the option "dev" (make TARGET=devo8 dev) the trainer port is used as as serial out.
21 Oct 2013 08:27 #14826 by EduardS
It's not compiled, it's the downloaded version. Gonna try the 3.0 version for the 8S this evening (CET).
  • rbe2012
  • rbe2012's Avatar
21 Oct 2013 10:35 #14827 by rbe2012
I tested it with the actual nightly again - also no problems.
21 Oct 2013 16:26 - 21 Oct 2013 16:27 #14840 by EduardS
:oops: Sorry my mistake. :blush: It's working now. I turned on the transmitter connected to the pc and then selected the simulator model. When I turn on the transmitter after connected to the pc with a simulator model already selected all channels are giving output. Thanks for all feedback to my question and sorry I took your time unnecessary.
Last edit: 21 Oct 2013 16:27 by EduardS.
21 Oct 2013 16:37 #14842 by vlad_vy
Replied by vlad_vy on topic Walkera +deviation firmware+which simulator?
You can press 'Re-Init' button after you select simulator model (PPM).
21 Oct 2013 17:25 #14848 by EduardS
Thanks for the tip vlad. That works also.
08 Oct 2016 06:57 #54707 by Josegonzalez1985
Replied by Josegonzalez1985 on topic Walkera +deviation firmware+which simulator?
Thanks for the info fellas, I was able to connect my devo 10 deviation to my pc easy, juSt had to select ppm as the protocol and connected right up
Time to create page: 1.098 seconds
